Question about Sony Televison & Video
My Sony 50W700A has a problem. no picture on the screen backlight is OK please help me about witch electronic board should change?
No picture backlight is OK Audio is OK HTMI and AV is OK
    Top Expert:
  • Sony Master
  • 75,462 Answers
If audio too is OK, the fault is with its T'Con board. If audio too is absent, the fault is with its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 24, 2016
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
  • 453 Answers
SOURCE: Sony Bravia 46S2010 LCD backlight ok , no video
yes it is
Posted on Jun 18, 2009
SOURCE: I have a Samsung LNT4665FX with screen problems. I
To solve this type of problem, you need a piece of white chalk. Draw a line around the area where the set is at. Call a priest - and lay the poor thing to rest!!!! This isn't the first time Samsung has "dropped" junk onto its' customers. Their dvd players also had problems with their DSP I.C.s that would over heat and cause the video playbacks to "break up". Don't waste any more time or money on the product!!!!!
Posted on May 18, 2010
  • 8457 Answers
SOURCE: no backlights
The T-Con board is dead.This board sit right in the middle in the bottom of the LCD screen panel.This board is dead,require replacement.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
Posted on May 24, 2010
budmrtn
  • 11361 Answers
SOURCE: I have an insignia NS-LCD37HD that has backlight
Chec to see if you are getting 12vdc at the T-CON board power input pin first.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 04, 2010
Testimonial: "So far so good! Almost got it figured out. Thanks!"
Samsung TV No Backlight Issue
Hi Cool,
Please disconnect the bulbs number one and solder a 4200pf/2kv capacitor in its place. See if the set works. Do the same for all the bulbs till you find the defective one. With the defective bulb replaced with 4200pf capacitor set will not power off. If this works and the light on the screen is sufficient, you can leave the capacitor soldered there. I hope it helps.
Good luck.
Nov 01, 2016 | Samsung Televison & Video
Lcd tv has sound no picture
Hi Chad,
Since you are getting the sound, the main board seems ok. Please show a flashlight on the screen, you should be able to see the picture there. If it is so, the backlights in your set are not working. Most LED TVs have LED driver circuit on the power board now days. Here a word of caution, there are two reasons for failed backlights. First the LED driving circuit and second the backlight itself. Which one has in your case, let some TV Tech decide it. In both the conditions your TV should be repairable.
Good luck
Dec 03, 2015 | Sceptre X505BV-FMDR 50" LED TV 1920x1080,...
No picture w/ sounds and backlight on
The screen controller circuit board isn't working. The board you're looking for is the one that has the wide flat ribbon cable coming from the bottom of the screen
Jan 05, 2014 | Sony KLV32S550A 32 LCD TV
Viewpia lcd tv backlight not working
Measure the input voltage to back light inverter board, from the main power regulator board. If it is found OK, replace back light inverter board.
Jul 27, 2012 | Televison & Video
The picture and sound come on then a few seconds later the picture goes off to black screen and sound stays on can you help please
hi,
Is there is any light in the screen at the time picture gose. If not, then Backlight inverter is faulty. All lcd tv have backlight to light the pixels. If you watch the screen very near then you will be able to see image on the screen. First of all check is there is any budged capacitors in the power supply. If there then replace it will solve the problem. If no then check the inverter board. Do on thing check the fuse in the inverter board. If the fuse is faulty then replace it. If the fuse blews again then the inverter board is short you have to replace invereter baord. It is not possible to repair the backlight inverter. You have to replace the board with a new one.Have added the picture of inverter board and budge capacitor for your reference. If you need any more assistance feel free to contact me by Fixya.
ajin_g_97.jpg ok
Sep 19, 2011 | Televison & Video
Can turn tv on picture comes on and then black screen can here sound and change channel
Tv turn on now,have a flashes a picture only a few sec. than picture died and have sound left ony?Yes,than ur tv have a 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter bords for the replacement.
Nov 24, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Black screen
Now tv turn on?Have a picture flickers a few sec. than just died,have only sound left?Yes,than the 1o 2 long board call the LCD inverter boards are dead.These 1or 2 long LCD inverters require changing to help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Jul 22, 2010 | Insignia LCDTV26 26 in. Television
Picture flicks off after it's been on for a while, and it won't come back on for up to an hour at a time.
The 2 long boards call the LCD inverter board,that the problems.These 2 long inverter board help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jun 09, 2010 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
No backlights
May 24, 2010 | Toshiba REGZA 47HL167 TV
No backlight on main screen
DEAR. Most chances are that ur phone flate cable has broken raplace it. but before to change u have to unplug the cable from connector clean it and reattach from both side board and lcd. if not ok then change cable.
Feb 07, 2007 | Sony Ericsson V800
Televison & Video Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
