Question about Serious Magic Visual Communicator 2 Studio Pro for PC
Cannot copy VC2 Studio1 :Data error (cyclic redundancy check) I can not finish installing my first disk in VC2 error number 1350 I try to transfer all the files to my desktop and when I try to transfer the VC2Studio1.Cab files gives me the error message that I wrote at the beginning of this message. I have some corrupt files on the installing CD What should I do? Anyone? PLEASE!
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Cyclic redundancy error when copying backed up files into Itunes
Files with cyclic redundancy errors means these files are corrupted and cannot be copied. Since you cannot copy these files from your faulty hard disk again then these songs are lost and you need to download them again.
Nov 27, 2012 | Apple iTunes
I am getting the data error (cyclic redundancy check)
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
  • Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
  • Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
  • Thanks for using Fixya.
    Jan 31, 2011 | Western Digital My Passport Essential...
    HI GOOD EVENING I AM UNABLE TO COPY MY MICROSOFT OUTLOOK 2007 PST FILE TO EXTERNAL HARD DISK. AFTER STARTING COPY FEW MINUTES LATER I FACE THE FOLLOWING PROBLUM CANNOT COPY OUTLOOK:DATA ERROR(CYCLIC...
    A "CRC" (Cyclic Redundancy Check) is caused by an disk-drive error.
    When you write a "block' of data to your disk-drive, a CRC value is calculated, and is also written to the disk. When you try to read that "block" of data, the CRC value is also read from the disk,
    and a new CRC is calculated from the data. If the "new" CRC does not match the "old" CRC, then you have a "check" condition -- either the data was not written correctly, or the data could not be read correctly.
    Now, did the "check" message refer to the "source" of the copying operation (namely your 'C:' drive) , or the "target"(namely the external drive) ???
    Try to copy the PST file to another file on your 'C:' drive.
    If you do not see the "check", then it is the external disk-drive that has a problem.
    If you do see the "check", then open Outlook, create a new folder,
    and copy a group of messages into the new folder. If Outlook reports that one of the messages could not be copied, then the disk-space occupied by that message is faulty, and must be excluded.
    Sep 07, 2010 | Computers & Internet
    When i trying to copy anything to my 2 gb memory card it says "cannot copy file data error cyclic redundancy check"
    Try to format the usb device by right clicking on the drive and then selecting format option. Try to copy your data after formating is finished and the device is ready to use.
    The solution is with the assumption that you are using a Windows Machine.
    Jul 27, 2010 | Computers & Internet
    In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear,
    All of the above is true, didnt write it myself copied it from a good friends post. It is probably the data itself that is corrupted. Doesnt mean the data is gone. Try running a disk defrag, if that doesnt work try copying it to a cd/dvd and see if you get the same error. If you dont, flash your bios. This should explain your problem, if it doesnt follow up with me, email address is kustom42 at gmail.com.
    Jul 14, 2009 | E-Machines eMachines Desktop PC
    Unable to copy files from cd
    Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
    Thanks
    Mar 01, 2009 | Computers & Internet
    Re-installing xp
    A cyclic redundancy check (CRC error) is an error checking program that is used to verify data and can be caused by hardware or software. The most common causes are bad CD disk, hard drive or memory. To run diagnostics press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Examine the Windows CD and see if there are any scratches or smudges on the media, try another CD disk if you have one.
    Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
    Thank You.
    Nov 13, 2008 | Dell Latitude D600 Notebook
    I am trying to install the Camedia Master software into a new pc, but when the disk gets to 90% loaded it freezes.
    A CRC error (Cyclic Redundancy Check) is a data corruption error. This basically means that the data read from the media did not match what was expected to be read by the software. I would say that it is most likely that the source media that you are copying/reading from is corrupted. It is also possible that the destination media that you are copying to could be the source of the problem. If it is a hard drive try running scan disk or other disk repair software, if it is a CD - clean or replace the CD. David Millier Advance Camera Repair
    Feb 25, 2007 | Olympus Camedia C-350 Digital Camera
    Open Questions:
    Serious Magic Visual Communicator 2 Studio Pro for PC Logo
    75 people viewed this question
    Top Serious Magic Computers & Internet Experts
    David Payne
    David Payne
    Are you a Serious Magic Computer and Internet Expert? Answer questions, earn points and help others
