James Bennett Posted on Dec 24, 2016
Need codes to program my scaner - Office Equipment & Supplies
5helpful
2answers
How can i solve this E244 error code
A E244 error code deals with the scaner. When you turn the copier ON will the scanning lamp turn ON? If it dose and you make a copy and thhe scaner moves & start to make a copy and then codes out. The problem is the BLACK scaner power cable has a crack in the coatting and is arching out to the frame o the copier..... It is not a easy fix.... If the scaner lamp is not turning ON???? You may have a blown Lamp or thermal fuse.... You can still find these parts..... The code will not go away till the problem is fixed.. Good Luck
1helpful
Hand held scaner
To enter a known frequency into the scanner's memory:
1. Power the scanner ON.
2. Press MAN to stop scanning.
3. Enter the number of the channel to be programmed (1 through 30) - OR - press the MAN key repeatedly to advance to the desired channel.
4. Enter the frequency including decimal point (ex: 146.25).
5. Press E to enter the info into memory.
6. Repeat steps 2 through 5 to program other channels.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
How to scan a document from Epson Stylus Photo RX620 into a computer
Hi you need to get a progran that has a scaner on it like a art program or photo program , I use PaintShop pro 7 It old program but works good there newer ones to be had.
All the best Pineworks
How to scan photos to the computer
start - program- lixmark scaner- click on it-the diloge window for scaner apper choice the dip as300 or more put 300 is good then choice the jpg for hoto to be very easy when you have save the photo make prevew for the picture the scaner will make scanning for the picture in the glass then will apper on you moniter computer select the part you want scanning by mouse then click scan when finish save it .make sure you instull the scaner in your computer good.
I need to install a printer,scaner,copier
You can download most of them from the printer company for free. Sounds like HP.com for you! Warning, when you install, make sure the printer is not connected to the computer until the installation program tells you to connect it. Have it plugged in and turned on and have the usb cable attached to printer.
I need a program guide.
Go to radio shack site. There is probably a manual you can download if you search the site. The catalog number for the scanner is 20-427. you can search by that number if the model number does not work.
Hp1610 scaner/printer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
6helpful
CanoScan Lide 25 scanner
driver scan saya hilang gimana cara mendownload drivernya
Having trouble with my knew uniden scanner
first you sec that your scaner data in cable is USB or OTHERS then you took a data cable and conect your scaneer your pc when you conect your data cable in your pc then you sec that your pc gave you amasage like that : FOUND NEW HARDWARE: then you put in your scaneer instollation disk your cd rom and instolle your scaner driver properly and use it isely.
2answers
How can I restore factry default?
open your programming manual,or setup manual and read the codes return to factory
k24674
ADMIN Andrew
ADMIN Andrew
