Question about Car Audio & Video
I have 12" kickers and have random problem.. they pulse rapidly for no reason.. turn car on off and problem is gone most of the time.. any ideas ?
  • Car Audio & ... Master
  • 5,529 Answers
Check the ground, make sure its a good chassis ground not close to anything else. also check all the grounds, the battery ground, the stereo ground.
On your amps speaker jacks if you have L+ and L- (or R+ and R-) connected to the same speaker it will cause this pulsing. you need to connect L- to R- for one speaker and L+ and R+ to the other speaker.
Posted on Dec 24, 2016
3 Suggested Answers
  • 3 Answers
SOURCE: BP1200.1 Car Audio Amplifier: is that amp good for 2 12 inches subs kickers 600...
that will most definitely be the best amp you will own and the only amp you will ever need to purchase.
Posted on Jun 11, 2010
yates_michae
  • 4 Answers
SOURCE: goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
Posted on Jan 30, 2012
Speaker blown?
disconnect the amp and do a "pop" test with a 9v battery, it should be clear and no rattle... if it rattles sub is blown
Jan 29, 2014 | Kicker Comp CVT 12 Car Subwoofer
My dual 2 ohm cvr12 kicker are burning on the red dot Connection what can it be and also the symtem hits fine for min then fade.
check that you have the correct impeedance polarity try turning down your amp gain most of the time its wattage match get as close of a match as possable ohms must be corect for amps specs
Nov 17, 2012 | Kicker Comp CVR 12 x 12 Car Subwoofer
Kicker SX900.2 turns on then says overload and shuts off
Sounds like one or more of the output transistors have gone and the amp protects itself from any further damage.
May 06, 2012 | Kicker Car Audio & Video
Can kicker 1000x1 amp detect if my speaker is bad and turn itself off?
The Kicker 1000x1 Amplifier does not turn off if their is an Open Line (blown sub) on the Speaker Terminals.
  1. Remove all Speaker Wiring from the Amplifier, leaving the Power, Ground, Remote, and RCA wires plugged in.
  2. If the Amplifier fails to turn on, check your Remote wire for power.
  3. If the Remote wire is powering up with the Head Unit (should be anywhere from 5-12 Volts), check your Power wire for +12 Volts, and check your Ground wire.
  4. If you are getting +12 Volts Power and your Remote wire is putting out 5-12 Volts but your Amplifier still won't turn on, it will need to be serviced.
Jul 24, 2010 | Kicker ZX10001 Car Audio Amplifier
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Kicker 550.3 amp will not power up
do u have the remote wire hooked up to the (rem) spot usally inbetween the pos and neg?
Mar 15, 2009 | Kicker ZR360 Car Audio Amplifier
Box size
http://kicker.com/Product_Manuals/93/104 , look at the tech manual, it will give you dimensions of sealed or vented and it will give you a couple of box ideas.
Feb 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Goes into protection mode for no reason
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
