Question about Amana Dishwashers
Amana SofSound 2 dishwasher started normally then stopped and now does nothing. Standing water in the bottom and no lights on the display seem to work. Help
  • 60 Answers
SOURCE: ldF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
Posted on Dec 20, 2007
aborcass
  • 2651 Answers
SOURCE: Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Posted on Feb 26, 2008
SOURCE: Amana Sofsound II Dishwasher, heated
push the button for a different option: it's like a radio button in Hypercard: one must be chosen, and choosing one will "unselect" the others.
Posted on Aug 14, 2009
  • 3 Answers
SOURCE: Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Posted on Sep 20, 2009
Testimonial: "Quick response. Thank you."
  • 21 Answers
SOURCE: standing water in bottom of dishwasher
The first thing to try is to clear out debris from strainer area, you may need a Philips head screw driver for this. Clear out and then attempt to put the unit through its cycle.
The second thing I would try, is unattach drain hose from drain to sink, either blow in it or use a blower side of shop vac to force air into the hose. Reset dishwasher, and try again.
Not knowing how handy you are, you can pull the dishwasher out, please turn off circuit before doing so, also make sure you have towels handy. Unattached drain hose at base of drainage pump. Clear out hose and remove debris on bottom of pump. Reattach the hose and run through cycle..
If these do not work your issue is with a bad pump.
If there is a
Posted on Oct 13, 2009
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
My Amana sofsound dishwasher is not cleaning the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 22, 2012 | Amana 24 in. ADB1500AWS Stainless Steel...
My wife started the dishwasher normally. Water
Quite possibly something lodged in the pump, locking it up. Control sensors don't advance timer because unit is not running.
Sep 11, 2009 | Maytag Dishwashers
2 H Flashing
Seems to me you having problem with Touch panel. 2 H means 2 hours delay. It is shows up because for some reason control panel got overheat and stock. But after it cool down it start working again.
Nov 26, 2017 | Maytag 24 in. MDB7601A Free-Standing...
Amana Sofsound II Dishwasher, heated dry display light won't shut off
Aug 23, 2008 | Amana Dishwashers
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
