In a sandpiper. 378fb it has two black tanks i want to know witch tank. collects what ? this unit has a stackable washer and dryer.
aborcass
  • 2651 Answers
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Posted on Dec 09, 2008
  • 512 Answers
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Posted on Sep 03, 2009
housejess
  • 317 Answers
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Posted on Nov 04, 2009
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Posted on Nov 15, 2009
graemevm
  • 519 Answers
SOURCE: Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Posted on Apr 18, 2010
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
I have a Goldstar model-GP120CE and it has stoped working and P2 appears on the display. I know the collection tank is full and im supposed to drain it but what and where is the collection tank??
There is two drain plugs on the back of the unit, you will need to drain the the bottom black plug, you need something to catch the water. hope this helps
Jul 11, 2009 | Goldstar Heating & Cooling
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
I have a stackable unit. The condensation dryer is on top of the washer. There is a light leak coming from the dryer. What can be causing this?
a leak from a condensate dryer is probably coming form the condensor itself, have you taken out the condensor and cleaned it lately, if so check the resivor where the condensed water is supposed to be collecting, have you emptied that?? perhaps it wasnt put back in properly???
Nov 02, 2008 | Bosch Dryers
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
I HAVE A BISSEL SPOT BOT THAT WON'T **** UP THE DIRTY WATER.I TRIED TO TAKE IT APART TO CLEAN IT, BUT DIDN'T GET VERY FAR. ANY SUGWSTION? THANKS, ...
No Suction
Possible Causes Remedies
Tank is full. Empty tank.
Dirty/Collection tank latch is not down. Push latch down, securely
into place.
Black Valve on the Dirty/Collection Tank is missing. Replace Black Valve into Dirty/ Collection tank.
Usually there is a seal out of place, or a filter is clogged, so you lose suction.
Apr 30, 2008 | Vacuums
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
