Question about Philips Televison & Video
Philips 21pt2125/94/c channels switching continuously
    Top Expert:
  • Philips Master
  • 74,106 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Dec 24, 2016
I have a Philips DVD recorder/player HDR3700. Works fine except when recording comes on the TV channel being watched changes to the channel being recorded which means I have to switch back to the TV...
Its a bug. I have one too and it does the same thing. Try asking Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 01, 2015 | Philips Televison & Video
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    Tv tuner 1730 stopped scanniong tv channels
    If you reinstall the driver and get the message "Driver not digitally signed", you should be able to click on "Continue anyway". Please try this first.
    Jul 18, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
    Turn on TV and it stays on channel 6 for 1 minute.
    the problem probably on the corroded channel and volume switch tri to clean the switch with a contact cleaner...you can buy it on the electrical/electronic store...also check for any corossion at the system ic on yhe main board. there are two big ic on the mainboard one is the jungle ic or chroma and the other one is the system ic which is feets are directly connected to the channel/volume switches
    clean the in between of the feets/terminal of the ic.and this will solve the problem
    May 20, 2010 | Philips Magnavox TP3285C 32" TV
    Philips 27S300 C101 TV. How do I program the channels into the Philips TV. It's hooked up directly to cable. Right now I need to type in the channel I want to view. The channel up and down button skips...
    use this user manual because you will continue to get some problems with your TV. print this use manual;
    http://www.p4c.philips.com/files/2/27pt643r/27pt643r_dfu_aen.pdf
    Sep 15, 2009 | Televison & Video
    Color loss when switching between HD and analog channels
    Clearly your T.V. is the problem. Always know: whatever unit needs the most adjustment needs, that is the unit that's gonna give first. It's an internal issue, one that should be checked by a service center. There are no connection issues. If it had been then the issue would be continuous.
    Aug 23, 2009 | Philips 26PF9966 26 in. LCD Television
    Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
    Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
    Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
    Televison & Video Logo
    29 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
