Question about Plantronics, Inc. Plantronics BackBeat Fit Blue
Can you overcharge the plantronicsBackbeat Fit
  • 2,045 Answers
Yes you can if you connect a wrong voltage charger to it.
Posted on Jan 18, 2018
What problems can occur when you overcharge the hvac
The level of overcharge will dictate the severity of the possible problems. The most common problem with overcharging is creating high compressor head pressure which over-amps the compressor motor which waste energy and shortens compressor life. Installed high pressure safeties will usually shut off the unit off and must be manually reset. High system pressure also results in higher evaporator temperatures and higher air discharge temperatures. Grossly overcharged systems could return liquid to the compressor, destroying it.
Sep 04, 2014 | Heating & Cooling
How to save from battery overcharge
Most laptops(newer ones) have technology in them that will prevent any type of overcharge. If you are weary or it is an older laptop you can unplug it once its fully charged and that will avoid any problems with overcharging.
Jun 08, 2013 | Computers & Internet
Can I use a trickle charger on a 2007 jag XK8 during storage for 45 days? R Smith
Yes you can use the trickle charge to keep the battery fit as it is stored up for such a long period. But at the same time the trick charging must be balanced or controlled not to over charge the battery . So if the charging unit has a cut off then it would be good as the battery will not be overcharged.
Hence you can try to get a good unit to keep your battery in trim condition.
Dec 17, 2010 | Jaguar XK8 Cars & Trucks
How long should you charge ur f&p voyager mobility scooter..after a trip of say 5-10 km ...i dont want to overcharge it and fry the new batteries.(2x 20 amp hr)
Hi. 20 amp hour batteries are rather small for one of these machines. You can fit up to 55 amp/hour batteries in these.
These machines have to have the programming changed for different charge rates for different batteries,e.g. Wet cell, sealed lead acid or gel cell.
These machines have a fully automatic charger that drops down to a float charge after the batteries have been charged. You cannot overcharge them. At the very least leave the machine on charge overnight after each use.
Batteries are built to do so many charge cycles, and the more they are discharged while using them the less cycles you will get. If you only use 25% of a batteries reserve you will get more cycles than if you use say 75% of a batteries reserve.
Good luck. Neil.
Feb 22, 2010 | Health & Beauty
2004 Accord; aftermarket headlamp blows
Is the globe blowing from overcharging ,vibration,excessive heat or poor quality globes.Take the globe to a auto electrician and they may be able to identify cause.The globe is easy to fit in upside down and if not seated properly can overheat.Alternators are starting to fail on these vehicles also,no aftermarket parts or alternators are available as of yet.Around $1400 for one from Honda.The most likely cause is poor quality globes or loose in globe holder.Fit brands such as Phillips or Tungsram.
Good Luck!!
Feb 12, 2010 | 2004 Honda Accord
Holds full charge for only 5 hrs.
this is about average for on full time! Don;t confuse 'Standby Time" with actual usage time in continuous usage. Earlier models only gave 2 hrs!
I made a mod to be able to fit an Opti-Sola charger ( quite small) That uses solar power to recharge or extend running time. There are also battery units fror Palm Zires that can be modified tro fit this unit to get extended time in the field If you want more details of these items get back to me. admin@nettiser.com.au
Pleasse rate our help++++Thanks for using FIXYA
Oct 09, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Car charger without overcharge protection - fear of overcharging Mororola Razr V3
you should purchase a mobile v3 car charger for the phone and do not use the other one you have
Sep 28, 2008 | Motorola Mobility RAZR V3
Plantronics, Inc. Plantronics BackBeat Fit Blue Logo
96 people viewed this question
Top Plantronics, Inc. Radio Communications Experts
John L radiodude365
Vladimir Frolov
Caitlin Romagna
Caitlin Romagna
Level 1 Expert
Are you a Plantronics, Inc. Radio Communication Expert? Answer questions, earn points and help others
