Question about Carrier Heating & Cooling
Carrier expression model 42P060HX how to work remote
I have a 15 ton carrier gas pack at work with inducer motor and spark igniter with hall senser ..showed error 6 flashes on igc board which the drawing said was inducer motor or hall senser...
The error code is always right. Sometimes misleading, but in 15+ yrs I've seen, always right. I'm not familiar with a Hall Sensor. If this is a remote sensor, as in a remote location that senses in the hall and not at the tstat then I know what you're calling a hall sensor. Make sure your IDM is working and closing the air proving switch. And that no other safeties are in that circuit. Check continuity to the remote sensor wiring and all connections? I've seen hot surface ignitors look fine and not work, but pulled a new off the truck and the new worked. All else fails, remote sensors are tough to get a good ohm value due to a temp difference affecting the ohms, replace it. I'm not sure why your "drawing" would relate the IDM to a remote sensor so I'd focus on the IDM and follow the voltage trail.
Apr 03, 2017 | Carrier Heating & Cooling
I have a carrier aircon model 428300HP-1 . It works ok but It does not t respond to the control remote commands. cant switch it on or off, have to do it from the main switch. control seems ok, batteries...
One of the sensor is defective whether receiving sensor in indoor or transmission sensor in remote.
Please try with another remote same type. If not you have to repair your PCB sensor.
Dec 26, 2010 | Carrier Heating & Cooling
On click on my pocket express app for my blackberry but it will not come up it worked earlier. I get the pocket express log on logo bu then a blank screen
Have you tried resetting your phone?
If not, that would be the first thing I would try.
With your phone powered on, gently remove the batter, then wait 30 seconds or so and then reinsert the battery and reboot the phone.
Does the problem still persist?
If so, a little more information would be helpful.
What is the model of BlackBerry you are using and on what carrier?
What version of the BlackBerry OS is on your phone? This can be found by selecting "Options" on your phone, then "About."
Was Pocket Express preloaded on your phone, or did you download it from PocketExpress.com, Handmark.com or elsewhere?
Please let me know what happens!
Oct 14, 2010 | Cell Phones
I have a carrier wall heater with a remote, and I don't have the directions for the remote. I can't turn the heater on! I press the power symbol, but nothing happens.
Hi, Sally378, I may need to get any model numbers you may have for the remote or the unit to solve this. If this remote has batteries you may want to change them to see if this takes care of it. If not, send me the model numbers from both the remote and unit itself.
Sincerely,
Shastalaker7
Jan 30, 2010 | Carrier XHD183D Air Conditioner
I need a remote for a carrier bca-101r wall unit. Or a compatible remote.
Get model number and call place of purchase or carrier customers service.
Mar 19, 2008 | Carrier BCA101R Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
