Question about Bosch Washing Machines
Front load Bosch washer sport throwing code 20 I think what does that mean and how can I fix it?
  • 1,381 Answers
Is it definatly errror code 20 as Bosh list error code 21 but not 20?
Posted on Dec 24, 2016
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
I think I need to replace the valve on my washing machine! I am a fix it virgin and need woman proof instructions!! Help please!!
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. You can search for the meaning of
the error code on the site.Don't worry about the
timer, they hardly ever go bad.Good luck with it.
If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Whirpool duet sport F 20 code
common F20 error requiring an about $35 water valve replaced. You can get parts and manual at repairclinic.com
Oct 14, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
E17 error code
Got an E17 Error today on a Bosch 6450 Series washer (the user manual says Bosch Vision 300/500/DLX series). Here's what I did to fix the problem.
- Tilted the unit back, propped up the front with some 2x4 (lying flat; that's all the room I had).
- removed 3 screws (Torx 20 I think) under the front lip. Then slid the cover (below the washer opening) down. This revealed the pump to empty the washer, a manual door lock opening pull rod, and a drain line (?)
- Looking through some holes in the front panel I saw some water on the bottom of the washer... but I spent a lot of time with the pump cleaning it out first (some zipper pull got in there and made a lot of plastic shavings). - Ultimately I got my hand the bottom of the washer and soaked up the water that I could find. That's when I realized
- there is a micro switch mechanism at the bottom near the front. This must be the "AquaStop". The mechanism contains a bit of styrofoam that floats up on any little amount of water that collects under it and triggers the microswitch. So, I removed that unit, wiped the water up... put it all back together. No more E:17 error.
Still don't know how the water got there in the first place though.
Mar 29, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Bosch front load needs new gasket
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
