How to test photocell on Remington Kerosene torpedo heater 60,000 BTU. Plug heater in fan runs then shuts right back off after 5 secs.
  • don-ohio Dec 25, 2016
    Maybe the ignition electrodes are not sparking? They sometimes burn back and need adjusted closer or replaced. don-ohio
    Problem Solver:
  • 7 Answers
You can find a service manual for that unit at www,desaparts.com and download the PDF.
Also I include the direct link.
Hot Surface Ignition Models Service Manual
Posted on Dec 27, 2016
5 Suggested Answers
SOURCE: remington 60 portable forced air heater 60,000 btu
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
Posted on Jan 16, 2009
koolbreezes
  • 540 Answers
SOURCE: Kerosene heater cuts off after a few seconds
Photo celll rarely goes out, but time to remove the gum out!---or OVERHAUL TIME!
Posted on Dec 18, 2009
  • 6 Answers
SOURCE: i have a 60,000 b.t.u. kerosene heater that runs
More than likely either the photocell is going bad.... or your flame is not strong enough... if the nose of your heater barely glows orange then your heater is not burning hot enough... if your heaters nose has a healthy orange glow then your photo cell is going bad and needs to be replaced OR if your heater has a circut board then you could possibly have a bad relay or a bad board.... if the nose of the heater barely has a glow to it while it is running then try turning your pump pressure up... there is an adjustment screw in the plastic cover of your pump which is on the back of the electric motor... it takes a straight screw driver head to adjust..... if that screw is all the way in and your heater is still barely burning then you need to tear the pump apart and clean the wheel and the 4 reeds that go in the weel.... tear off the plastic pump cover that houses your filters.... then take the metal face plate off that is behind the plastic cover (usually 6 screws) now your wheel should be exposed.... those 4 little reeds should FREELY slide in and out of the slot... if they dont.... then take them out of the wheel and take a scratch pad and clean both the reeds and the slots on the wheel they go in until they freely slide up and down... hope this helps
Posted on Dec 27, 2010
heatman101
  • 43501 Answers
SOURCE: I have a reddy kerosene
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Feb 20, 2011
Thermoheat dtu torpedo heater reads E1 error
These are some possible causes:
1. Wrong pump pressure
2. Dirty Air Output,Air Intake or Lint Filter.
3. Dirty Fuel Filter.
4. Dirt in Nozzle.
5. Dirty Photocell Lens.
6. Photocell Assembly not
Properly installed.(Not seeing the flame)
7. Bad electrical connection between photocell and MAIN PCB assembly.
8. Defective Photocell.
If all those check out ok, then check these:
1. No fuel in tank.
2. Wrong pump pressure.
3. Carbon deposits on spark plug and/or improper gap.
4. Dirty fuel filter.
5. Dirt in Nozzle.
6. Water in fuel tank.
7. Bad electrical connection between ignitor and MAIN PCB assembly.
8. Ignitor wire is not attached to spark plug.
Nov 29, 2013 | Protemp 125000 BTU Kerosene Forced Air...
Heater starts, fan runs, injecting fuel but won't fire up
heatman101
Jan 20, 2011 | Reddy Heater 60,000 BTU Kerosene...
Ingition shuts down within 30 seconds. I realize this is the auto shut down, but there is no reason for it to do this. I took the cover off and found it would stay lit and run if I didn't tighten the...
Can be the Photocell {eye} at the back of the burner or the inline fuel filter.Photocells are easy to replace and when you install the new one make sure it's aiming straight to the flame.Inline filter can be cleaned by using forced air,but not recommended.Filters are cheap.If none of that works check the air pressure at the pump,rear of machine,little plastic pipe plug.4 to 5 P.S.I
Dec 23, 2009 | Reddy Heater 60,000 BTU Kerosene...
Dec 18, 2009 | Heating & Cooling
I have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Sep 19, 2009 | Reddy Heater 60,000 BTU Kerosene...
Torpedo heater runs for a minute or two then the breaker trips.
You can test the photocell by hooking up a ohm meter on thr rx1k scale. Photo cell should be out of the heater.Hold photocell up to a light bulb,with light on resistance of photocell should drop to 0 to 100 ohms.Holding finger over the photcell and blocking the light the resistance should go up to the maximum resistance
Jan 31, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
