Question about Philips Audio Players & Recorders
Cannot get any sound from my Philips nx7 stereo system
Cannot get any sound out of my Philips nx7
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Dec 24, 2016 | Philips Televison & Video
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
I just bought a Philips Smart WiFi Bluray Player BDP2105F7 and I cannot connect it to my old tv which is a sony triniton, I have image but no sound. There are two outputs on the dvd player but I have...
Your white red yellow cord is a Stereo sound + video cord. The red and the white ends are for sound the yellow end is for video - if your TV is not stereo it may not have the red and white it may only have one in which case you need to find an adapter from stereo to Mono to fit your red/white cable ends into a single connection on the TV. Or you can buy a home theater sound system and it will give the TV its signal and it will keep the stereo signal and broadcast it through the sound system.
Sep 15, 2017 | Philips Televison & Video
Sound distortion on medium volume with radio, cd, aux, ect.
The problem is in the audio driver or output stage which is normally an ic semiconductor, it is recommended that a technician look at the stereo to assess cost.
Sep 24, 2012 | Philips FWC527 CD Shelf System
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
We have just bought a 2004 Vogue Caravan with a CD/DVD player...Philips...but there are no instructions..it is wired to a system that players music in all areas of the caravan. Can you help please.
Might be connected to the actual stereo as an auxiliary item so the caravan stereo may have to be turned on and set to auxiliary in order to hear the surround sound.
Mar 02, 2011 | Philips Audio Players & Recorders
I have lost he remote for my Philips LX600 sound surround system . I need a code to . Can I use one for all remote to replace lost remote ?
For basic and advanced functions,I've had REALLY good luck with Philips Universal MULTI-FUNCTION remotes- Particularly the long slender silver multi-function models,and they will come with Philips functions pre-enabled-just be sure to get one w/the CORRESPONDING button for amp/receiver/stereo/stereo in-a-box,and check back of remote package to see if it operates Home Theater In a Box [HTIB] However,w/OneForAll remote,you would need to give the model # of the remote. Good Luck!
Dec 21, 2009 | Philips Home Cinema Amp + Speaker system...
Surround sound for my home theater.
you cannot output sound from your xbox to another dvd system , you can however send the sound to your tv and output the signal to a stereo or home theater system if your looking to have surround sound or looking for stereo sound , the tv should be set to video1-2-3 and thats where youll be able to have sound and picture , , thanks sincerely glenn
Mar 03, 2009 | Philips HTS3400/37 System
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
