Question about Canon Office Equipment & Supplies
My Canon printer MP630 has 6A80 error. I have turned off power as shown but with no result! Have checked the manual & tried again without success! Please can you help me?!
  • Canon Master
  • 824 Answers
I suspect you have had a paper jam and removed the paper. However some still remains inside the machine. Its most probably around the purge unit. When the carriage parks on the right side of the machine, the purge unit rises to cap the carriage so your print head does not dry out. Open the internal cover so you can see the carriage. If it is anywhere other than at the far right side of its travel then kill the power by unplugging from the mains supply. Now the carriage is free to push. push it all the way to the left side. Shine a torch into the printer and you will see the purge unit on the right side. It has two black oblongs of rubber that mate with the print head. There will be paper scraps around it.Or it may be stuck and with a long screwdriver you can push it gently backwards to free it. If none of this helps and the carriage is stuck on the right side then again kill the power and rotate the long black roller that is under the carriage. Do this while gently trying to push the carriage to the left until its free to move then follow the above again.
Posted on Dec 25, 2016
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Canon mx357 code error 6000 soultions
sir i have a canon pixma mx357 printer. it gives a code of 6000 (printer error has occurred turn off power then back on again. if the problem persists see the manual) shown in the window. will u please give me the suggestion to repair the printer. my e mail id is
Jul 04, 2012 | Canon Office Equipment & Supplies
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I have a Canon W8200 and i get the error code"
Try this:
1) As an error (E02802 or E02805 to E02809) is shown on the display, install the correct
combination of printhead and ink tanks according to the error.
2) Perform ink filling*3 following the installation sequence. After filling ink, when "Load Roll
Media" is shown on the display, turn off the power.
3) Turn on the printer while holding down the ONLINE button, ENTER button, CANCEL button,
and PAPER SOURCE button.
4) Check that "Canon W8200" is shown on the display, and then release the buttons. When
printer enters Reset mode for the dye/pigment model setting, all the LEDs on the operation
panel turn on.
5) "TYPE RESET" is shown on the display.
6) Select "YES", and then reset the dye/pigment model setting in the printer.
When reset is selected, the ink drain sequence is executed. It takes approximately 4
minutes for the process to be completed.
7) Check that "Turn Power Off!!" is shown on the display, and then turn off the power.
8) Unplug the power cord from the outlet.
9) Move the carriage, and then takeout the printhead.
10) Replace the following parts
• Ink tube unit : See "Part 5: 5.2.6 Ink tube unit".
• Purge unit : See "Part 5: 5.2.9 Purge unit".
• Ink tank unit : See "Part 5: 5.2.10 Ink tank unit".
11) Turn on the printer, and then continue with the installation operation (from installation of the
printhead). At this time, replace the printhead with a new one*4.
For service manual, You can write me on
Hope that helps!
Jul 29, 2011 | Canon W8200PG InkJet Printer
Hi there!
If you're getting the error code B200 when you try to print on your Canon PIXMA MX850, there is nothing you can do except to have it repaired. This error code indicates a Voltage High Error of the Canon printer. If the printer is still under warranty, please contact Canon for further assistance.
Jun 26, 2011 | Canon PIXMA MX850 Multifunction Printer
My canon mp530 printer had a check cartridge error U052, but then it changed to check printer 6800 and it won't work. is there a cure?
6800 must be EEPROM error.Try this:
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (you're still holding the POWER button during this). The printer mechanics will move momentarily. You're in SERVICE MODE now.
Press the RESUME 3 times.The lamp will alternate color with each key press.Then press POWER button.Wait 5 mins and press POWER again, the printer will turning off.
If this not help printer may need service.
Oct 15, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Jul 16, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printer/Fax machine
find solution
Mar 19, 2008 | Brother MFC 6550MC Laser Printer
old marine
old marine
