Question about Kitchen Ranges
My Hotpoint cooker hood makes a constant vibrating noise when not in use. It can be stopped for a while by switching on/off or by opening/closing kitchen door. I have checked outside vent flaps .
  • 833 Answers
SOURCE: flap valve and noise
The flapper valve is a weather valve. Usually, it is installed in such a way that the flapper is vertical and closed. The pipe is installed on the horizontal...you'll need an EL pipe. Pivots allow it to open when the fan is on. If you don't install it, wind will blow into the unit and you will be rather unhappy.
It is possible that the sound you hear is normal when opened up. With all the covers in place, it should be nearly silent.
http://www.zephyronline.com
Posted on Dec 09, 2007
manhandy
  • 146 Answers
SOURCE: kitchen hood not venting outside
check to see if the dapper is opening. that is piece of metal in the flue that keep the air from the outside coming in or check if there is something plugging the top part of the flue on the roof. plus you can go roof and look down and see if there is anything blocking it.
Posted on Jun 24, 2009
heavyt15
  • 91 Answers
SOURCE: Our hotpoint cooker hood lets cold air in.
That's the best solution.....
Posted on Nov 04, 2009
  • 491 Answers
SOURCE: Is there an outside cooker hood vent available
FIRST CHECK THE FILLTERS IN YOUR HOOD UNIT AND SEE WATH KIND THEY ARE IT SOUNDS LIKE THEY ARE USELESS , YOU SHOULD REPLACE THE HOOD FILLTERS WITH CARBON ONES AS THEY HAVE A LONG LIFE AND ARE VERY GOOD AND WORTH THE COST .
Posted on Nov 17, 2009
  • 1891 Answers
SOURCE: my friend as a parkinson cowan cooker and she has
this web sight offers shop manual's .. you will need model and ser # this will get you a parts break down and part # ect .. there is on most oven doors 2 to 3 screws or ( H ) brackets that hold it together .. you may be missing some of these .. hope this will help mm
Posted on Dec 02, 2009
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
My car is making an awful groaning grinding noise noise when it starts. The noise stops after it starts. Put my foot on the brake it starts again. put thr car in reverse no problem put it in,drive it...
It's your exhaust mounts or broken exhaust bolts. It does it in drive st idle n under load because the motor is sitting in rubber mounts made to dampen vibration. Therefore the motor tilts to the left in reverse pulling the exhaust away from your under carraige, and to the right in drive causing the loose exhaust to vibrate against something. Check your heat shields also. They fall apart n do the same noise. Piece of cake.
Sep 24, 2012 | Cars & Trucks
Our Samsung fridge srs757dw is making weird noises(it hums loudly). When the Freezer door is open it stops but as soon as it closes the noise begins again. What do you think is the problem?
Sometimes this can be due to vibrations within the duct , possible that the ventillating fan is frosted and so makes the noise with the door closed. So shut down fridge for few hours to defrost and check.Also make sure there are no loose screws or clips on the back panel and the evporator section that can cause vibration.
Aug 30, 2011 | Samsung Televison & Video
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
THE DOOR ON MY HOTPOINT WMA64 DOES NOT REGISTER AS BEING CLOSED
The most common cause of this is the sensor wire inside has vibrated loose and is no longer making a connection to the switch. Those switches rarely fail. It's a very easy fix, only need a screwdriver. I would, however, use a small plastic ziptie to hold the wire to the switch.
Oct 06, 2009 | Hotpoint WMA64 Front Load Washer
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
