Question about Fossil Watches
How to remove metal band from a fossil blue watch
  • Fossil Master
  • 18,424 Answers
this video will show you
Posted on Dec 25, 2016
  • 3 Answers
SOURCE: watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Dec 31, 2007
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: Remove link from Watch Band
I would suggest that you take it to local jewler or watch repair center, it normally runs less then $10 to remove an unlimited number.
Wal-Mart used to be a good place to go, but have since decided to support only watches that are sold in the store, which are crappy at best.
If you want to do it personally...I would discouage it. It is normally a simple process but without training, can turn into a big problem with minimal effort.
Have a great day!
Posted on Jan 13, 2009
slp11508
  • 43 Answers
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
I need a replacement band for a fossil watch number 741010; I see a number on the band of 7413500. Could you help me find a replacement band?
On the back of the watch should also be a 6 digit code consisting of 2 letters and 4 numbers. For instance CH3000.
With that code you should be ablte find your strap here: http://www.mastersintime.com/en/straps/
Oct 17, 2017 | Fossil Watches
Where can I get extra links for the band?
Moto 360 - Extra links for metal watch band - Motorola Support
https://motorola-global-portal.custhelp.com/app/.../prod.../2815,9141
Your metal watch band can be expanded by adding links. The small gray envelope inside the watch box (see image below) contains four extra metal links.
Order Links & Bands - Fossil
https://www.fossil.com/us/en/.../order-links-and-bands.html
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Parts Archives - Citizen Watch - English (US)
Dec 25, 2015 | Watches
I would like to have aexpansion metal band for my fossil watch and cannot find one
mcdevito75 here, Ebay is the place to shop for a new expansion band. Maybe even a small watch repair shop in your area.
Aug 19, 2010 | Fossil Watches
How to remove links from a metal fossil watch band
mcdevito75 here, To reove the links you"ll need a special tool called a link remover available on ebay, or you can look for a small watch repair shop in your area for about the same cost of the tool and save on delivery time as shop can do the job right away.
Aug 07, 2010 | Fossil AM3726 Wrist Watch
Ihave a fossil blue watch, and need links for the band. where can I locate some?
Contact Fossil customer care and they should be able to supply them. Here is their web address:
http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html
Aug 01, 2010 | Fossil Watches
How to adjust a metal watch band Fossil Casual Metal Dial AM3861 Watch for Women
mcdevito75 here, Best bet since you would need a couple of tools to adjust the band size is to look for a small watch repair shop in your area to save on the cost, the cost of a shop to adjust the band is about the same as the tools needed, since these adjustments are in frequent let the watch repiar shop do the job.
Jun 18, 2010 | Fossil Casual Metal Dial AM3861 Watch for...
How do i remove links from a fossil metal band.. watch
Look for screws in the links or pins. Sometimes "hairpin" looking keepers are used to remove a link.
Dec 05, 2009 | Fossil AM3726 Wrist Watch
Remove links from fossil metal band
Jan 09, 2009 | Fossil Arkitekt watch
I need to replace a fossil watch band
call foleys or dillards and ask for the number to the company
and thy can assist you
Jan 06, 2008 | Fossil CH2331 Wrist Watch
Watches Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
