Question about Freezers
Sub-Zero model 550 does not cool properly
The freezer is cooling properly. The refigerator take a long time to cool and lately we have had to keep adjusting the cooling control to a higher number. We are now at 10 and it takes hours to maintain 40. The coil does not have frost on it. Could we have a leak in the coil. Is it hard to replace a coil. Unit is 13 years old and out of warranty.
    President:
  • Freezers Master
  • 1,922 Answers
Make sure the coils are clean first both coils, then check the r22 freon
Posted on Oct 05, 2009
The freezer works but not the refigerator
Hi Jan - Typically if the compressor is running but only the freezer side is not cooling properly than more than likely the unit has a faulty temperature control. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset to assist with the repairs.
Jun 18, 2013 | Frigidaire FKCH17F7HW 16.7 cu. ft....
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
Freezer doesn't cool but refrigerator works fine
Check the relay on the freezer compressor. It may be shot.
Apr 16, 2011 | Sub-Zero Freezers
Our sub zero refrigerator compressor kicks on for about 30 seconds then kicks off. The freezer is not working properly
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 06, 2011 | Sub-Zero Freezers
Our sub zero seems to defrost in cycles. Not sure why ice cream melts in there while other meats remain frozen. Is this an expensive problem?
The defrost may be lasting too long....and ice cream is always the first thing to melt... you need at least 10 F to keep ice cream hard...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Sub-Zero Freezers
Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Sep 15, 2009 | Freezers
10+ years old sub zero 550. ice cubes are green
I would not recomend using those ice cubes. Sounds like theres lots of mold or worse growing in your freezer. I would get rid of it. ;(
Jul 09, 2009 | Freezers
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Freezers Logo
263 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
