Question about World Heating & Cooling
My kozy world wall heater makes a boom pop when it lites. It's like a delay in lighting and then it lites.
    Problem Solver:
  • 10 Answers
If the furnace made a clicking noise trying to turn on and then makes the BANG noise at the furnace, it’s most likely a delayed ignition. Imagine a room full of gas and then someone decides to light a match. Big problem. That's what’s happening in your furnace if the ignition of gas is delayed.
A variety of issues can delay the combustion of that gas. So the gas builds up in the furnace until—BOOM—it ignites, causing a mini-explosion. This can harm the heat exchanger, which is very expensive part to replace. Some causes of delayed ignition includes:
1. Dirty burners
2. Flames are lifting away from the burner outlet due to too much primary air
3. Too much gas
If you're handy enough to understand what I've said then burners can be cleaned/replaced, and primary air can be adjusted. With some units gas flow can be adjusted as well; other times the gas valve will need to be replaced.
If you've no idea what I've described, GET HELP before you ruin the heat exchanger and have a more expensive problem on your hands or worse...
Posted on Dec 24, 2016
  • 118 Answers
SOURCE: The pilot light on my kozy world ventless wall
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Posted on Oct 26, 2009
  • 221 Answers
SOURCE: Kozy World propane wall heater
The ceramic "bricks" need to be heated evenly. Since 3 are good, I would have to assume the other two have a restriction. Maybe a spider in the orifices, If  you can access the "jet" where gas comes out, try using a paper clip or something similar to clear any blockage. If that wont do it, pull the burner, remove each orifice and clear. Good Luck
Posted on Dec 30, 2009
Testimonial: "Thank you very much for the info. There was some trash around the opening of the 2 jets. I cleaned them out with a tip cleaner and now it works fine."
  • 8404 Answers
SOURCE: Is there a way to convert a kozy world KWN313
Your model is not listed at http://www.kozyheat.com/.
If this is currently a natural gas fitted device, there is a better than not chance it can be converted.
Please check with the manufacturer or dealer where you purchased the device. You can also contact your local propane supplier who would do the actual converting of the orifices.
A note: If this device is presently set up for natural gas and is hooked up, and you still have natural gas available, this is normally the cheaper of the two fuels to use.
Thanks for your quesiton at FixYa.com
Posted on Jan 02, 2010
  • 4736 Answers
SOURCE: My pilot light on my
From what you have described there appears to be dust, dirt or pet hair in the pilot or the pilot tubing, as well as the Oxygen Depletion Sensor (ODS). OR your heater may be the wrong gas type. In other words, you have Propane Gas and the heater is a Natural Gas heater (or vise versa). Look for the manufacturers tag on the side or back of the heater. It will tell you the model number, serial number and gas type. Even with this, on rare occasions, the manufacturer's plate may be incorrect. The only way to be sure is to remove the front cover of the heater and look at the control valve. It should be marked LPG or NG.
Posted on Jan 28, 2011
  • 4736 Answers
SOURCE: I have three Kozy World wall heaters. Two work
Yes, it sounds like the third heater has a Control Valve problem. It's allowing more gas into the system than what it's supposed too. Have you tried turning the flames down to a lower setting? If so, did it lower the flame height? How old is this heater and is cleaned and serviced at least annually? Are you using Natural Gas or Propane?
Please get back to me with the answers to the above questions and I may can help you.
Thanks,
Rich
Posted on Feb 07, 2011
1. Dirty burners
3. Too much gas
Dec 24, 2016 | World Heating & Cooling
My Kozy heater turns off after a few minutes, I then have to re light it and when it kicks on again after a few mins it turns off again. It will stay lite if I turn it down but when it goes on agin it will...
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.
1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)
2. Make sure that the tip of the thermocouple is in the pilot light flame.
3. Make sure that the thermocouple is clean.
Mar 22, 2011 | The Companion Group Kozy World Portable...
Pilot flame pops and gets llonger then shorter
From what you have described, it sounds like a pressure problem with the gas. Contact Kozy World (you can find their home page on line) and speak with their Tech Service Dept. Also, the gas in the tank pay be very low.
Jan 31, 2011 | The Companion Group Kozy World Portable...
Pilot light is very small on kozy world ventless wall heater
Probably dust in the pilot safety ODS chamber. I like to flush the pilot with rust buster. but shop air will work. More here
Oct 09, 2010 | Procom (177653) Utility Heater
Dec 30, 2009 | Heating & Cooling
The kozy wold heating stove flame has irruglar
kozy world KW112, 1 burner is dim flame 2nd flame is bright red. What is the problem?
Dec 09, 2009 | The Companion Group Kozy World Portable...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
Oct 26, 2009 | The Companion Group Kozy World Portable...
Kozy world propane wall heater. The pilot light will work
Sounds like you have a common problem with infrared heaters. They are very dust sensitive and they will light and then go out when they are dusty. If you have already tried to blow it out at home you need to take the heater to your propane dealer who will take the heater apart and blow it out correctly. They will then hook it up to their gas line and make sure that the problem is fixed. I hope that you haven't blown up into the bottom of the heater where the gas line is connected. There is a diaphragm up in there and if you blow into it you risk messing it up to where it won't work at all.
Nov 15, 2008 | The Companion Group Kozy World Portable...
Heating & Cooling Logo
24 people viewed this question
Top World Heating & Cooling Experts
don-ohio
Andrew Taylor
Andrew Taylor
Are you a World Heating and Cooling Expert? Answer questions, earn points and help others
