Question about Samsung Refrigerators
Samsung French door refridg., bottom of door handles need tightening? How to get to screws?
Mod. RF26J7500SR, about 4months old.
  • 833 Answers
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Posted on Dec 21, 2007
SOURCE: Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Posted on Mar 28, 2008
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
How do I reattach handle on freezer door pull that has come unscrewed on French Samsung refrig
Many times the handle is slid on from one side or the other onto the screws. Try sliding the handle off by gently putting a screwdriver or putty knofe under the handle on the side that is still attached and pushing the handle sideways. This should remove the handle so you can remove the mounting screw and get it back on the door. then you can slide the door handle back on after getting the screw attached on the door again.
Oct 04, 2014 | Samsung RF265AA Bottom Freezer French Door...
I have a 2006 kenmore elite trio refridgerator wirh french doors and bottom freezer. on of the door handles is loose. what tool do i use to tighten handle. each handle has a screw at top and bottom. The...
There is two allen set screws for each hand at both end and they are facing each other on the handles.. Remove the allen screw and put a very minute speck of jelly on each screw---small-small amount. This will kept the set screws from loosen up. GB...stewbison
Aug 31, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Bottom door handle loose
There is a 3/32" allen set screw on the under side of the handle. Just tighten the set screw and your problem should be resolved.
Aug 24, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Nov 07, 2008 | GE Refrigerators
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Oct 15, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
