Question about World Heating & Cooling
My kozy world wall heater makes a boom pop when it lites
    Problem Solver:
  • 10 Answers
If the furnace made a clicking noise trying to turn on and then makes the BANG noise at the furnace, it’s most likely a delayed ignition. Imagine a room full of gas and then someone decides to light a match. Big problem. That's what’s happening in your furnace if the ignition of gas is delayed.
A variety of issues can delay the combustion of that gas. So the gas builds up in the furnace until—BOOM—it ignites, causing a mini-explosion. This can harm the heat exchanger, which is very expensive part to replace. Some causes of delayed ignition includes:
1. Dirty burners
2. Flames are lifting away from the burner outlet due to too much primary air
3. Too much gas
If you're handy enough to understand what I've said then burners can be cleaned/replaced, and primary air can be adjusted. With some units gas flow can be adjusted as well; other times the gas valve will need to be replaced.
If you've no idea what I've described, GET HELP before you ruin the heat exchanger and have a more expensive problem on your hands or worse...
Posted on Dec 24, 2016
  • 118 Answers
SOURCE: The pilot light on my kozy world ventless wall
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Posted on Oct 26, 2009
  • 221 Answers
SOURCE: Kozy World propane wall heater
The ceramic "bricks" need to be heated evenly. Since 3 are good, I would have to assume the other two have a restriction. Maybe a spider in the orifices, If  you can access the "jet" where gas comes out, try using a paper clip or something similar to clear any blockage. If that wont do it, pull the burner, remove each orifice and clear. Good Luck
Posted on Dec 30, 2009
Testimonial: "Thank you very much for the info. There was some trash around the opening of the 2 jets. I cleaned them out with a tip cleaner and now it works fine."
  • 8404 Answers
SOURCE: Is there a way to convert a kozy world KWN313
Your model is not listed at http://www.kozyheat.com/.
If this is currently a natural gas fitted device, there is a better than not chance it can be converted.
Please check with the manufacturer or dealer where you purchased the device. You can also contact your local propane supplier who would do the actual converting of the orifices.
A note: If this device is presently set up for natural gas and is hooked up, and you still have natural gas available, this is normally the cheaper of the two fuels to use.
Thanks for your quesiton at FixYa.com
Posted on Jan 02, 2010
TheMobilian
  • 8220 Answers
SOURCE: pilot light is very small
Probably dust in the pilot safety ODS chamber. I like to flush the pilot with rust buster. but shop air will work. More here
Posted on Oct 09, 2010
  • 4736 Answers
SOURCE: I have three Kozy World wall heaters. Two work
Yes, it sounds like the third heater has a Control Valve problem. It's allowing more gas into the system than what it's supposed too. Have you tried turning the flames down to a lower setting? If so, did it lower the flame height? How old is this heater and is cleaned and serviced at least annually? Are you using Natural Gas or Propane?
Please get back to me with the answers to the above questions and I may can help you.
Thanks,
Rich
Posted on Feb 07, 2011
My kozy world wall heater makes a boom pop when it lites. It's like a delay in lighting and then it lites.
1. Dirty burners
3. Too much gas
Dec 24, 2016 | World Heating & Cooling
My Kozy heater turns off after a few minutes, I then have to re light it and when it kicks on again after a few mins it turns off again. It will stay lite if I turn it down but when it goes on agin it will...
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.
1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)
2. Make sure that the tip of the thermocouple is in the pilot light flame.
3. Make sure that the thermocouple is clean.
Mar 22, 2011 | The Companion Group Kozy World Portable...
I have three Kozy World wall heaters. Two work just fine - the bricks turn red after the heater has been on for a while. The third one always burns blue and the flames 'lick' the top of the inside of the...
Thanks,
Rich
Feb 07, 2011 | The Companion Group Kozy World Portable...
Pilot flame pops and gets llonger then shorter
From what you have described, it sounds like a pressure problem with the gas. Contact Kozy World (you can find their home page on line) and speak with their Tech Service Dept. Also, the gas in the tank pay be very low.
Jan 31, 2011 | The Companion Group Kozy World Portable...
I have a Kozyworld wall mounted ventless propane heater. Whenever it automatically turns ON or OFF you get a strong odor of propane. While it is ON you don't smell propane. What is wrong with it. I...
You need to clean it out. Take the wall heater down and use a air compressor to clean out the gas system. Also clean the orifice out. Make sure that the chamber is clean and clear of spider webs and dust.
Jan 26, 2011 | The Companion Group Kozy World Portable...
Dec 30, 2009 | Heating & Cooling
The kozy wold heating stove flame has irruglar
kozy world KW112, 1 burner is dim flame 2nd flame is bright red. What is the problem?
Dec 09, 2009 | The Companion Group Kozy World Portable...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
Oct 26, 2009 | The Companion Group Kozy World Portable...
Heating & Cooling Logo
Top World Heating & Cooling Experts
MightyMikeJr
Donni Steen
Are you a World Heating and Cooling Expert? Answer questions, earn points and help others
