I refilled my cartridge(12 A desmat) and also changed its drum. But its print in coming very dull. Would anybody help me in this regards, plz.
I refilled my cartridge(12 A desmat). Print was very dull hence, I changed the drum also. Again print is coming very dull. Shopkeeper told me there is some problem in your printer. He tested the same cartridge in his own printer and got very fine print. I used other cartridge in my printer that is printing good but refilled cartridge giving dull print. Would anybody help me in this regards, plz.
SOURCE: test print great, document printing blurred
try to heat up the printhead of the cartridge on hot water about 90degre celsius and clean the head whit a clean soft paper (toilet paper is great and cheap) and make a clean nozle on the printer software.
Posted on Oct 22, 2007
Joed911
  • 4338 Answers
SOURCE: hp psc 1500 constnatly blinks check printer cartridge and does no
According to this HP document, the problem is with the ink cartridge(s):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00308379&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You may want to try a reset:
Reset the HP All-in-One Follow the steps below to reset the All-in-One.
  1. Turn off the HP All-in-One by pressing the Power or On/Resume button.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the Power or On/Resume button
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 23, 2008
  • 77 Answers
SOURCE: error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Posted on Apr 28, 2009
SOURCE: Brother HL-4040CN won't read or show new refilled cartridge in the LCD
I think I know what the problem is...
When you refill these toner cartridges you need to reset the "toner empty" cog wheel.
For instructions on how to do this follw this link:
http://www.proprint.co.uk/brother_hl4040.htm
It has pictures and explains how to reset the cartridge
Good luck,
Billy.
Posted on May 13, 2009
  • 1751 Answers
SOURCE: It won't print in black, after refilling the cartridge.
try sucking from the bottom with a refill clip in order to remove the air that is in the cartridge and holds ink in the sponge
look in this video for a success refilling
http://www.youtube.com/watch?v=MPi2GqJg5QM
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Dr Print
Posted on May 01, 2010
Hl3040cn prints a black stripe down the page despite the drum being cleaned as advised by Brother.Peter
Hi
3 issues might be the problem.
1. The toner waste compartment is full. You need to clean the toner waste compartment located in the cartridge itself.
2. Roller drum inside the cartridge have lines normally starts on both ends of the drum. This due to bulky printing. Check and replace this parts inside the toner cartridge. Manual cleaning is not advisable because the result will still the same. If you have only toner cartridge, use the roller drum and replace in place of it.
3. Faulty Toner Cartridge that cause leaking the toner powder. If you purchase remanufactured toner cartridge or you refill the toner cartridge. It tends to worn out the parts. Normally starts as roller drum and follows with the other parts. Replace new original Toner Cartridge. When you refill the toner cartridge, you need to clean the waste compartment as well as it will later be full and overflow.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 15, 2011 | Brother HL3040CN Laser Printer
12A cartridge after refilling is printing ghost print repeating ...plz how to rectify problem.. what is the problem....
replace cartriage then you can identify the problem is in printer or cartriage if the problem is in printer the problem creater is teflon sleeve. In other case the problem is of opc drum Change the cartriage opc drum then check
Jan 01, 2011 | HP LaserJet 1010 Printer
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Streaking on left side of page
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | HP LaserJet 1200 Printer
White line
White lines are generally caused by clogged print nozzles. I assume that you have a printer with the print heads built into the cartridge. Are you using high quality cartridges or cheap refills? If cheap refills, try a better/different brand of cartridges and see if that helps. I would also check the printer manufacturers website and try their recommended printer nozzle cleaning procedure.
Jun 03, 2009 | HP LaserJet 3055 All-In-One Printer
In printing there are un wanted black batches and lines.i have changed drum two times. so i am unable to control it . please help me hp laser 1100 printer
have u changed the cartridge it self u are buying a new one right no refilled stuff if thats the case drum cartridge and the thirs thing is may be piece of paper is stuck inside which got wet with the ink every time u try to print it gives u lines on print pls try this and tell me or tell me the status of ur cartridge and drum
Feb 23, 2009 | HP Office Equipment & Supplies
Changing ink cartridge
Using refilled cartridges is not at all recommended as it may damage the firware of the printer. I request you to replace the refilled cartridges with genuine ones and I am sure that should resolve the issue.
Regards,
Lawrence
May 11, 2008 | Office Equipment & Supplies
Please
if you are using original hp catridge (not refilled) u got warranty exchange it
else change the drum it costs around 4$
Thank you
Take care
Bye
Apr 15, 2008 | HP LaserJet 1020 Printer
k24674
jasbo
jasbo
