Question about Sony Televison & Video
My sony plasma Monitor turns on and click's to standby and i have no picture
    Top Expert:
  • Sony Master
  • 74,871 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Posted on Dec 24, 2016
  • 5 Answers
SOURCE: my plasma tv go's to standby while I'm watching it
I have the service manual and it has a lot of symptoms for your problem can you tell me exactly what happens when you first start the TV but it sounds like a scan converter problem This is what I got from the service manual page 4
4-2. Self Diagnosis Function
4-2-2. Criteria for Judgment of Abnormality
11. Detection of abnormality in communication with scan
converter.
(Name of this function on the service menu : OTHERS)
Warning when communication with scan converter
cannot be performed normally
or this could be it
14. Detection of PDP failure.
(Name of this function on the service menu : Nil)
PDP is suspected to be defective when DIGITAL 5 V
is normal among the voltages (VS, VA, DIGITAL 5
V) required to drive PDP while both VS and VA are
not inputted.
When all the following conditions are satisfied, the
machine enters once to the STANDBY mode then turn
the main power back on again.
1) DC 180 V power is 40 V or less.
2) DC 70 V power is 20 V or less.
3) DIGITAL 5 V is normal.
The above-described operation is repeated three times.
If the above three conditions are still satisfied, the PDP
is judged to be faulty and the main power is shut
down.
I can send you the manual if you want it
Posted on Sep 21, 2009
SOURCE: Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Posted on Oct 31, 2009
  • 11 Answers
SOURCE: sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Posted on Apr 07, 2010
eagle338
  • 4889 Answers
SOURCE: lg model 42pm4m plasma monitor won't turn on, red
Does the tv make a clicking noise like its trying to turn on before the tv goes into standby and the LED starts flashing? I suspect this is due to a shorted component, most likely to be in the 5V(switching) line and just want to be a bit certain before we start testing the power supply.
Posted on Jul 31, 2011
diodeic
  • 1622 Answers
SOURCE: 42" plasma worked fine this
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Sep 15, 2011
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Sony 42 inch plasma tv standby light just flashes tv
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony plasma standby light flashes 8 X, won't stay on
when pluggin power it turns on and immediately move to standby
Dec 28, 2008 | Sony PFM-42X1 Plasma TV
Sony Plasma TV.
Dec 28, 2008 | Sony FWD-50PX2 50 in. Plasma Television
Monitor goes to sleep mode quickly without video cable
right click on desktop - click properties - click screensaver tab, and dropdown menu to none. this turns off screen saver. For power/hybernate....
start - control panel - power options. Change all pull down menus to "never"
Problem solved.
Dec 22, 2008 | HP vs15 15"LCD Flat Panel Monitor
Sony Plasma TV
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 12, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Sony FWD50PX2 Black Plasma monitor
Same problem - my warranty is for two years, so Sony repair is coming out to fix it. Last time it made the clicking noise they had to replace the main power supply board. The problem this time might be something else. Check your warranty paper to see if you too have a two year warranty (on-site) and check the sony web pages for a sony repair center near you.
Nov 22, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Tv/Monitor shuts off and on by itself
I have a complete set working all panels with a duff pdp panel - i will happliy sell you the boards please call me on 07940 025730 for details cheers.
Oct 31, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
