Does this tv top come apart from the bottom in two pieces
  • kakima Dec 24, 2016
    Hi John Lyons, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "this tv"?
2 Suggested Answers
electronick
  • 505 Answers
SOURCE: I have a Mitsubishi Ws-65907
There are 4 plastic plugs (2 per side) that cover the allen wrench screws holding the top to the bottom. You will also have to take screws out of the back and pull the speaker grille to unhook the control panel. After unhooking and unscrewing everything, the tv will split in half.
Posted on Dec 07, 2008
Rm-yd029 sony remote mute button not working
Hopefully this isn't too late for you. It will at least be available for others who face our problem.
Step 1: Remove the battery cover.
Step 2: Remove the screws that are under the battery cover.
Step 3: Remove the sliding panel at the bottom of the remote. Gentle pressure under the center of the door will lift it over the retaining tab. You might have to apply a little pressure on one side of the door to get it to release. Again... GENTLE.
Step 4: Work a very thin screw driver into the small gaps at the bottom of the remote in the area that was under that sliding door. I used a jewelers screwdriver. Gently work the blade around and back and forth until you hear a tab pop. Then get the other side's tab to pop. Use fingers and blade to get that end segment to pop open.
Step 5: Carefully work your way up both sides of the remote with the screwdriver releasing tab after tab. You can pop one on one side and then go after the matching one on the other side. Sometimes you can do two at a time on one side before doing the other side. Try not to apply pressure on the silver/gray side trim. It is decoration only. Get the blade in between the black top piece and the black bottom piece to pop them apart. Do this along the sides up to the top.
Step 6: The retaining tabs that are at the very top of the remote can be released with a gentle pulling apart and slight twisting of the top piece and bottom piece. Everything should be open and the layers should come apart easily.
Note: Be aware that the plastic frame parts on the big circular pad in the center of the remote face may fall out when you pull things apart. Not a big deal. Just make sure you reassemble it correctly. Be patient and look closely at it. It goes together pretty much one way and has sized tabs that help to get it right.
Step 7: Do whatever cleaning you need to do. For my situation, some liquid had gotten into the volume control area. I used a q-tip to clean it up.
Step 8: Before snapping it back together, fit all of the layers in the bottom piece then do a test of the buttons to make sure they work. (Replace the batteries if you removed them, of course.)
Step 9: Assuming all of the buttons worked and you are ready to reassemble, transfer all of the layers into the top piece (best done with the top piece upside down) and make sure they fit well. Make sure the two silver/gray trim pieces are firmly in place on the bottom layer. Hold the upside-down bottom piece above the upside-down top piece and snap the bottom piece into the top piece.
Step 10: Recheck that the buttons work. Re-open and try again, if necessary.
Step 11: Assuming all the buttons work, replace the sliding panel from step 3. Get its tracks aligned with the remote's tracks and it should be a simple pop in. Heavy force is not necessary.
Step 12: Replace the screws
Step 13: Replace the battery cover.
Hopefully this worked for you.
Aug 19, 2012 | Televison & Video
Can't separate agitator. Have tried extreme force to separate the top from bottom. There must be some other way on this unit. Whirlpool Ultimate Care II. Have removed agitator but the two halves won't come...
There are small but strong plastic tabs that hold the 2 pieces of the dual action agitator together. Look into the center from the top with a light you will see them. If you got the agitator out. 1 bolt 7/16 socket holds it in and down, seperating the 2 pieces to get to the dogs should be easy.
Oct 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
White screen replacing fliex cord need instrutions
As far as I know no one has directions for this.Your on your own.You need to take all the screws out of the phone.The phone basically snaps together.your going to need a security bit type screw driver to take out the screws.Take the phone to a hardware store or sears and check to see what size the screws are.I believe your going to need a number 7 security bit..some times there called a hex key also.You need to take off the back bottom cover.it snaps on.there are 2 screws under the cover.and there are 2 screws on the top of the phone in the back also.you need to unsnap the phone covers apart.Be careful because there is a separate piece that covers the cable and attaches to the phone.The cable runs through that piece.Your going to have to remove the top screen from the casing.No easy way of doing this. just use a skinny screw driver and gently pry it apart till you can pull it apart.You can see where it goes into the casing.After that you may need to take off the silver metal screen over the lcd screen.You can see the cable attaches to the bottom socket on the far left and the other end to the board for the phone.I think there is a piece also covering the cable or bottom part of the lcd screen. that snaps apart but is hard to snap together again.It's round and looks like one piece,but it's actually two pieces.Since both phones are the same,just use one as a guide how it goes back together.I may have skipped a step or two but that's basically how it comes apart and goes back together.Once you take one apart you can see how it's put together and reverse the steps.
May 31, 2009 | Motorola Mobility E815
Need to know if TV can be separted into 2 pieces
Yes it can and does come apart in 2 fairly equal sized pieces. There are some screws on the sides when removed the top half with the mirror will lift off. It may require some extra force the first time it is done but comes apart with ease after that
Feb 25, 2009 | Mitsubishi WS-65411 65" Rear Projection...
I have a Mitsubishi Ws-65907 I know it comes apart in two pieces Iwould like to give this TV to my father How do I take apart the top fromt he bottom. Any help thanks!!!
Dec 06, 2008 | Mitsubishi WS-65907 65" Rear Projection...
How to get to mirror and lenses on a pioneer SD-643HD5?
unplug tv. Remove 4 screws from bottom of tv in front right below speakers on right and left side. Bottom panel slides up and out. Don't disconnect just rest panel on front of tv. Remove two screw at bottom of trim strips on each side of screen. Each one of these strips will slide down and remove. Last piece to remove is trim strip at top of screen. There are no screws to remove. The whole piece simply slides to the right about 2" to 3" inches then will unlock from mount brackets. Pull towards you and slide up and off screen. carefully lift screen up and out of bottom brackett. Top trim piece may be a little tight. Just tap on it with the palm of your hand and have somone pull on strip from other side.
Oct 18, 2008 | Pioneer SD-643HD5 64" Rear Projection...
HITACHI 65XWX20B - How to disassemble the cabinet?
The 65XWX20B comes apart in 2 pieces - there is a top half and a bottom half.
- The bottom half houses all of the electronics, projection lenses, etc. It is very heavy and should be moved with care.
- The top half is basically just the screen.
I have moved this Television multiple times, even up and down from a 3rd floor apartment!
- First remove the screws holding the top and the bottom, the important ones are on the sides of the TV.
- This is important, I suggest 3 people do this part: Slowly lift the top away from the bottom half of the TV, but -not- very far. There is small wiring harness that that attaches the top of the TV to the bottom to a circuit board. This must be unplugged by one person while the other 2 hold the top half of the TV slightly above the bottom half. Note carefully where this plugs in so that you can reassemble easily.
- Once this is disconnected the TV is much easier to move, although still quite heavy and bulky. Do not turn the TV on its side - keep it upright while moving.
Reverse this process to put it back together.
Once you have done it once it is quite easy.
Good luck.
Jul 29, 2008 | Hitachi Director's Series 65XWX20B 65"...
Wingman Contacts Dirty, Cannot Open Cover
The the ring with 5 like screws is just cover that can be gentle forced out with a flat screwdriver. Then comes off the power control and the rubber gasket. Finally the top cover comes out. Simple.       coco13cos(Romania)
Jan 03, 2008 | Logitech WingMan Extreme Digital 3D...
Headphone Jack
the plastic pieces on the top and bottom are just stick on. pry them off gently and you'll find four of the tiniest screws on the top and bottom(you'll need a precision screwdriver) after you remove the screw pull the metal pieces on top and bottom off carefully with the screwdriver. the whole piece is shoehorned in, but it will push out just far enough to reveal the aux. jack. you'll probably find that this piece is cracked and that is why it only play through one or no sides. i'm still looking to find this piece.
hope this is helpful to you,.
Dec 12, 2007 | Dell DJ MP3 Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
