Question about Pioneer Audio Players & Recorders
Setting up ARC on my pioneer receiver - Pioneer Audio Players & Recorders
CaRC not working on my vsx823
With some of these elaborate setups, the receiver overrides your settings and connections to configure a default arrangement for certain functions. The rationale for this is often buried obscurely in the equipment instructions. You may have to resort to trial and error, connect and disconnect to get a satisfactory result.
Dec 01, 2013 | Pioneer Vsx-821-k Receiver
Amp shutting down when volume gets too high
Easy! You either have a surround speaker wired backwards or there is a break in the wire leading to a surround speaker that is allowing the +&- to arc together. your amp shutsvoff as a protection to keep the arc from reaching the mother board. replace your wires man!!
Nov 29, 2012 | Pioneer Audio Players & Recorders
It has blue and green arc colors showing up with duplicate words at the lowest part of the screen-just showed up yesterday It is a Pioneer Elite projection monitor receiver PRO-710HD
Replace Both of Your STK ICs They are Big Black ICs will have STK392-110 on them upgrade ICs to 120s-150s,or 180s Call Mat Electronics for parts
1-800-628-1118 ICs will be on the Left hand side of Chassis Mounted on The very First board,there are screws holding board on Fame/ board also plugs in bottom of chassis.
Jan 21, 2010 | Pioneer PRO-710HD 64" Rear Projection...
No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Sep 15, 2009 | Pioneer VSX-D509S Receiver
DVDLD stuck on defaualt setting
There is a signal select switch witch if depressed will change the dvd/ld switch back. give it a shot.
Jan 29, 2009 | Pioneer VSX-D411 Receiver
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
