Question about Kitchen Appliances - Others
DO YOU PUT WATER IN THE MAIN COOKER BODY BEFORE PUTTING THE ALUMINIUM BOWL WITH RICE AND WATER INTO.I HAVE SR-928 PANASONIC ELECTRIC RICE COOKER.
  • 8,220 Answers
I do not think you would add water to the cooker. You simply add water and rice to the bowl.
Mine works great. I put 2 cups water and 1 cup rice.I add a tad of salt and olive oil. I cover the lid. set that into the cookerI press the lever. When the rice is done the lever pops up like a toaster. Note. Unplug the cooker when rice is done. that is how mine works. I would be willing to bet it is how yours works too.
Posted on Jul 21, 2009
Help! I accidentally poured water into my rice cooker without the bowl in it. What should I do now?
Dry it out thoroughly with hairdryer if necessary and then try switching it back on and cross fingers.
Mar 13, 2015 | Panasonic Kitchen Appliances - Others
Look for national rice-o-mat model SR-3F
I have this rice cooker (it's very small) and the original instruction booklet:
HOW TO USE
1. Measure rice with measuring cup. One cup of uncooked rice will make about 3 cups of cooked rice.
2. Wash rice 4 or 5 times with fresh water in another bowl. Wash until water becomes relatively clear.
3. Put rice and water into the pan. As a rule, add water to uncooked rice in the following standard proportions.
2 cups rice to 2 - 2 1/2 cups water
3 cups rice to 3 - 3 1/2 cups water
4. Place the pan directly on the internal heating plate, and make sure that the pan is properly located on the heating plate by turning it slightly to the right and left as shown. (see CAUTION) . Before placing the pan in the cooker, wipe off water and moisture from the outside (especially the bottom) of the pan.
5.Put on the lid.
6.Insert the plug end into a wall outlet.
7.Push the switch button to the "ON" position. Make sure the pilot lamp is on. When the rice is done, the switch will turn off automatically, the lamp will go out and a click will be heard.
8.Even after the switch is off, leave the lid on for at least 15 minutes more. During that period, the rice will be properly steamed to a fluffy character by the retained heat.
SOME HELPFUL HINTS
• Always tasty rice
With your National Automatic RICE•O•MAT you can have uniformly cooked rice ... you can even cook rice to your personal taste and preference. Taste and degree cooked depend upon the quality of the rice and the length of time it is soaked before being placed into the cooker. Add more water than specified for softer, more fluffy rice; less water for firmer rice.
• Rice may bubble over ...
If you use too much water or if the cooker is tilted, rice may bubble over. To prevent rice from bubbling over, add water using the cup included (refer to How to use, Item 3.)
HOW TO CLEAN THE COOKER
Do not immerse the body into water or spray water onto it. Wipe it clean with a wet dishcloth soaked in hot water.
Nov 21, 2012 | Kitchen Appliances - Others
Where do i add the water
A rice cooker is designed to heat the water to steam, infusing the rice (or vegetables) with moisture, and removing the excess water by evaporation. Your rice cooker may or may not have come with a steam tray (used to keep the items you want to steam out of the water, but still allow them to heat via the steam). It most likely did come with a deep bowl with a non-stick coating. This is where you pour the rice and the water. Make sure to put the lid on and turn it on when all ingredients are inside the nonstick bowl. Place the bowl inside the electric burner (or the cooker). I would add a little bit of oil to the water to improve texture and stickiness.
Jun 11, 2012 | Sunpentown SC-1811 Rice Cooker
Lost manual for panasonic SR-WO6NA 3 cup rice cooker
Assuming you actually mean the Panasonic SR-W06NA, you may access the manual here.
May 07, 2012 | Panasonic SR-W06NA 3-Cup Rice Cooker
Is the measurements for rice and the water the same as with a regular 1 cup measuring cup
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
Jan 30, 2011 | Panasonic SR-G06FG 3.3-Cup Rice Cooker
How much time it takes to cook rice in rice cooker
heatman101
Jan 27, 2011 | Panasonic SR-W06NA 3-Cup Rice Cooker
Looking for national sr-mm10n inside alumino bowl where to order
From Canada, here is a listing of parts, including the bowl for your cooker:
http://www.forumappliances.com/c-158-Rice_Cooker.html
Jan 22, 2010 | Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice...
Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice Cooker
After extensive web search, this seems to be the only Website listing Panasonic parts:
http://www.partstore.com
Aug 09, 2008 | Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice...
Steamer/rice cooker
you can put at least 3 glasses of water.(depends on how big your glass is).
its up to your prefernce when you want to put the food. but it much better to put the food when the water starts to boil.
hope this helps!
cheers!
Dec 24, 2007 | Panasonic SR-W06NA 3-Cup Rice Cooker
Kitchen Appliances - Others Logo
188 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
