Question about KitchenAid Kitchen Appliances - Others
Kitchenaid slicing blade lever is stuck - KitchenAid Kitchen Appliances - Others
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Slicing blade for George Foreman salad maker
Here is the accessories page with the different blades:
http://www.theconsumerlink.com/bosch/list/BUILTA/102/1
-Tha Mp3 Doctor
Posted on Mar 31, 2009
How do I remove my cracked support bearing on my Kitchenaid food processor 1333?+
Do you mean the bearing on the motor shaft within that circular plastic ring that moves up and down when moving the slicing thickness lever? If yes then a couple of screwdrivers under it one on each side to lever it up. At the same time it will force the black shaft sleeve up and off the motor shaft.
Oct 13, 2016 | KitchenAid Food Processors
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
My toaster flashed a "2" and the lever won't stay
My toaster is blinking on 2 and not working? My booklet to it doesn't say anything about this problem.
Mar 21, 2011 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
The lever won't stay down
The lever will not stay down. Sometimes the lever will catch and other times it takes 6-8 times befroe it will stay down and toast the bread. Thanks....
Oct 16, 2010 | KitchenAid KTT570 4-Slice Toaster
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
One side will not stay down
un plug it take it over to the kitchen sink or a garbage can turn it up side down and shake the begebers out of it ...I know sound silly but you would be amazed at how often it works a tiny piece of ....well what ever can affect the delicate workings of a toaster I know you wouldn't do this but for the other people reading this post while at the sink please resist the urge to put water in the toaster to clean it out....Good Luck
Oct 12, 2009 | KitchenAid KMTT400OB 4-Slice Toaster
I want to shredd zucchini to freeze for later use in zucchini bread. Lost manual. What blade should I use
To shred it into thin strips, use the blade with a series of holes in it. To slice, use the blade with a knife blade in it.
Sep 11, 2009 | KitchenAid KFP760 12 Cups Food Processor
The locking mechanism in our 2 slice Kitchenaid toaster does not work. Is there a way to fix this?
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Jun 23, 2008 | KitchenAid KTT570 4-Slice Toaster
Kitchen Appliances - Others Logo
50 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
