My slicing blade lever is stuck can't adjust slicing thickness any ideas???
2 Suggested Answers
How do I remove my cracked support bearing on my Kitchenaid food processor 1333?+
Do you mean the bearing on the motor shaft within that circular plastic ring that moves up and down when moving the slicing thickness lever? If yes then a couple of screwdrivers under it one on each side to lever it up. At the same time it will force the black shaft sleeve up and off the motor shaft.
Oct 13, 2016 | KitchenAid Food Processors
Will 51 cubic foot of foam insulation, cover 400 square feet of a wall?
That depends upon how thick the foam insulation is. That is the only way to compute from cubic feet to square feet.
To simplify, assume the foam is 1 foot wide by 1 foot thick by 51 feet long. That is 51 cubic feet of foam. If you slice the block lengthwise at 1 inch intervals, you get 12 slices, each 1 foot wide by 51 feet long by 1 inch thick. This is 51 square feet of coverage at 1 inch. You would be able to cover 51x12, or 612 square feet.
Increase the thickness of the slice to 1-1/2 inches, you only get 8 slices, or coverage for 408 square feet.
Any thicker than that, and you won't get enough coverage for 400 square feet.
Aug 05, 2016 | Cars & Trucks
My blade adjustment lever is stuck in the highest position
Hi Cindy:
Blade height is achieved by raising or lowering the deck so it sounds like you really only may have one problem.
If the height adjustment lever is stuck and will not move, it should be fairly straightforward to look at the various components to see where it is binding, and then make corrections as necessary.
Safety First. Have the engine OFF and the key removed before you start exploring the bits.
Sep 24, 2015 | Garden
How long to dehydrate apple slices
There are way too many variables to answer that question. You should refer to the owner's manual for your dehydrator. Some of the variables are the air temperature, humidity where you live, does your unit have a adjustable thermostat, does your unit have heating coils, how thick are you slicing the apples.
Sep 18, 2015 | Kitchen Appliances - Others
What areas of the Regency wood stove do I clean so that the fan blows stronger?
Many times, the fan blades themselves are the cause of lowered air flow. Think of the blades edges as though they were the cutting edges of a knife. You know a sharp knife cuts its products better than a dull knife....transfer that concept to airflow. A clean blade is sharper and slices through the air much better than a thick edged dirty and dull fan blade. I've seen extreme cases where the edges were 1/8" thick and the area between the blades nearly filled with lint, dust, dog hair and the like.
Service the blower blade first and while removed inspect the inside of the stove in front of the fan with a flashlight and small mirror. That will tell you if additional cleaning is required. If your motor is a cheap little 'shaded pole' motor, it could just be dragging and operating at a lower rpm than designed, delivering less airflow. If so, it may have to be replaced. There are no oil ports on most of these small motors.
Nov 12, 2014 | Home
Blade shadt adjustment
run a bit of timber through and measure the sides for the same measurement. adjust the thick side up till it is the same measurement both sides.
Apr 29, 2013 | Craftsman 1212 in Thickness Planer
Lever that lowers the blades is up/off position
did you check blade belt and check to see if blade is bent if not you have a broke blade houseing
Apr 17, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
How to adjust the slicer attachmenton the mixer attachment
take the attc. apart on the back btm of thecutter assy. there is a hand nut loosen shaft should slide either up or down depending on the thickness you want then tighten nut
Nov 03, 2009 | Hobart A200 Stand Mixer
15 people viewed this question
