Hitachi SF-H800TPX Washing machine comes up with E3 error on the spin cycle..Pump emties the water but no spin...
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
SOURCE: HITACHI WASHING MACHINE MODEL SF-60.
HI,
MY MACHINES MODEL IS KW-D502-HITACHI,
MY QUESTION IS ,HOW TO USE PERFECT?
Posted on Aug 06, 2008
SOURCE: Hitachi SF-H800PX my machine is
water supply malfunction.....maybe the inlet valves???????
Posted on Apr 10, 2009
  • 103 Answers
SOURCE: WASHING MACHINE WON'T EMPTY
the drain pump is defective.
Posted on Oct 24, 2009
Testimonial: "thankyou. suspected it was a problem with the drain pump. old machine has been good to us. favour not worth fixing. off to the shops."
blueextc3221
  • 15935 Answers
SOURCE: hitachi sf-6500fx washing machine does not power-up
Circuit breaker is in a panel of your house... not on the machine itself.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I have hitachi washing machine appear lode model SF-100JJS error p9 please tell me what is solution, ?
That is an F not a P. The codes are generic. It is a pump clog, block, or defect.
SOLVED: I am getting F09 error code - Kenmore Elite HE3 Washing ...
https://www.ifixit.com/Answers/View/47460/I+am+getting+F09+error+codeMar 20, 2011 - The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, ... The Kenmore Elite HE3 is a washing machine by Kenmore. .... hi i have f9 display always when i start machine can you help with this. hitachi washing machine f9 error Google Search
May 09, 2016 | Washing Machines
Wont pump out comes up with E3 on display
CLOGGED WATER PUMP HINDERING DRAIN AND SPIN CYCLE
Jun 11, 2015 | Washing Machines
I got C4 error on Hitachi FX80GJ washing machine and it stopped spinning. How can I fix it ?
Hitachi washing machine top loading is Sher coming C4 is dry too much sound coming
May 16, 2015 | Washing Machines
Hitachi sf-95kj washing machine stop and shown error code c4 when it's go to spin mode
A lot of new machines need the hoses cleaned out. The slime up. The pump gets shut down and the unit won't spin. Unplug unit before you service it to avoid shock. Top has to come off, and front also.
Nov 16, 2013 | Washing Machines
Hitachi sf-6500px error
Possible error on the program due to a memory issue. After resetting, if the machine has the same fault with all the selected programs, then it is possible that the motherboard is faulty. Please check the INLET flow to be good and the drain pump to be clear.
Jun 25, 2013 | Washing Machines
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Aug 31, 2007 | Washing Machines
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
