Question about Garmin GolfLogix GPS-8
Golf logix locks up
I may have the same issue described by others. Software update has created an issue with lock ups. Removal of batteries doesn't solve it.
Re attaching the unit to the base software works for awhile, but then it locks up again.
hydetech
  • 113 Answers
SOURCE: garmin c510 software update
You don't say if you tried resetting the 510 after the update.
To do a reset remove the grey faceplate trim piece.  Along the right side of the screen there is a reset button. Press the reset button then plug the 510 into a power supply. The 510 should automatically power up and reboot.
It's possible that the update was corrupted when it was downloaded, or there is a problem with the processor. If you can't get your GPS to reboot, your PC wont recognise the GPS and you'll probably have to send the unit out for service.
If you have already tried the reset please rate as "thanks for trying"
Posted on Oct 29, 2007
SOURCE: When GPS is turned on unit locks up
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Garmin
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Posted on Feb 03, 2009
  • 63 Answers
SOURCE: My Golf Logix does not work, it keeps freezing up
click on help in the course manager software, then click on "How Do I restore my golflogix unit". connect it and turn it on. when it tells you its restored, turn it off and on, and load your courses again. FORE!
Posted on Jul 09, 2010
  • 63 Answers
SOURCE: Golglogix locking up
Make sure to wait until you press okay on your computer when loading courses before you unplug the unit. I was jumping the gun, unplugging it right when it turned off, and causing that issue myself with mine.
  • 1116 Answers
SOURCE: I updated software on unit,
You may wish to perform a master reset and clear all of the problems this way:
To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1100, 1200, 1300, 1400, 1600, 2200, 2300, or 2400 series device:
Note: A master reset will erase all waypoints or Favorites and will restore your unit to the default factory settings. If you would like to back up your Favorites to your computer, you can find instructions to do so here.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes*
The device will automatically reset. Follow the on screen prompts and then place your device in an area with a clear view of the sky until it acquires satellites.
*If the text language on your nuvi is not set to English, touch the button on the right.
Posted on May 27, 2011
Golf logix 8
it should change by itself.
May 11, 2010 | Garmin Golf Logix GPS
The unite only stays on for about 15 min and then
Did you check the setting, it maybe on power saver mode?
Apr 13, 2010 | Garmin Golf Logix GPS
Golf logix for my blackberry ' network error, cannot find host'
If you have verizon, you need to turn GPS services to location on (options, advanced options, GPS) and you need to make all the permissions for the program "Allow"
Apr 08, 2010 | Garmin Golf Logix GPS
Unit will not power up (with new batteries)
call golflogix at 8779770162. BE SURE TO TELL THEM THAT IT HAPPENED WHEN YOU LOADED THE SOFTWARE UPDATE! otherwise, they might not warranty it.
Aug 03, 2009 | Garmin Golf Logix GPS
I bought a replacement serial adaptor for my golf logix. However, the wire sent to me is not the one that originally came with this unit. I was told that the they had problems with the original cord. Any...
Make sure that the arrow is pointing to the batteries, and that the cube is ALL the way to the bottom of the socket, with no space between it and the bottom at ALL. I suggest twisting the plug left and right while pushing down with your thumb.
Aug 02, 2009 | Garmin Golf Logix GPS
My gps has changed distances on my home coures for the last two weeks
Buy an update kit or bring it in and have the software upgraded.
Jul 23, 2009 | Garmin Golf Logix GPS
Unit comes on and locks on a single hole and thaty's it.
You need to download the 3.5 software from golfgps.com and then update courses on your unit.
Jun 08, 2009 | Garmin Golf Logix GPS
MY GOLF LOGIX HAS WORKED FOR OVER 2 YEARS . NOW IT WILL NOT AQUIRE SATELLITES. OTHER GOLF LOGIX IN MY **** WORK FINE
The GolfLogix 7 had a problem that if you did a reset to factory defaults it wiped out the Almanac in the GPS. This is the Table of where the satelites are. Put in a fresh set of battery's....turn it on and put it out in the open sky for 4 to 8 hours. Sometimes this will work. If not contact Golflogix Tech Support. They ill probable ship you a replacement unit.
Apr 07, 2009 | Garmin Golf Logix GPS
Golf logix does not stay on
hi what you need to do is take out the battery then restart the device if it works all good if it does not work trun off the deivice and throw it out the window in the garbage
Nov 24, 2008 | Garmin Golf Logix GPS
Garmin GolfLogix GPS-8 Logo
60 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
