My WestinghouseTvv blank in and out when you are watch it and it do it every few minute how can i stop it from doing that
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
How do i set the time for my adidas ADP6002?
The watch looks and feel great; the band doesn't hurt my wrist like other watches. The instruction book, however, was awful. It was a bunch of instructions for other watches, not the ADP6002. It took a few minutes of playing around for me to figure out how to set the watch. Here's how to do it: 1) Make sure there is a little "t1" above the second hand. If there is a "t2" instead, hold the Start/Stop button for 3 seconds. (This is the part that was messing me up) 2) Hold the Set/Light button for a few seconds. The watch should say LIGHT and "OFF" or "ON" should be flashing. 3) Press the Mode button until the hour hand starts flashing. You can adjust it up and down by the Start/Stop and Lap/Reset buttons. 4) Press Mode to adjust the minute, second, and other settings. 5) Press Set/Light button when you are finished.
Jan 04, 2011 | Adidas Digi III Watch
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Anytime i watch a video it will start then stop after a few seconds, then start again and stop. It will do this continually and with every video i watch.
what you need to do its try and let the whole video download for a few minutes before you try and watch it. it always works for me. good luck i hope i helped. :)
Aug 04, 2009 | YouTube Computers & Internet
It stops for a few minutes then runs well again
The problem that you have is with the watch's circuitboard. Inside this circuit board you have what is called a quartz chrystal, which transmits direct pulses to the circuit board, as for the watch to run properly. And as it is not at all possible to regulate or adjust the function of the crystal's pulses, which itself is integrated in the circuit board, there is no other way than to replace your watch's circuit board.
P.S. If you do not have the necessary watchmaker's knowledge to fix this yourself, you will have to find your nearest watch repair shop, and ask for help.
Please rate if this was helpful.
Jul 30, 2009 | Timex Expedition T41261
Display of My Dell Vostro 1500 goes 99% Blank/Dark After 1-5 min.
Try to repair your windows by using windows original CD. For best assistance you can watch this clip;
http://www.youtube.com/watch?v=KNOQ0sCYY8s
Please report back to the thread with results of your work.
Regards;
Hassan
Jul 22, 2009 | Dell Inspiron 9400 Notebook
T-Touch just stops and goes blank, then will restart without notice
the problem of your watch is circuit block,or lcd liquid crystal digit,try to replace the circuit or lcd,
Aug 23, 2008 | Tissot T-Touch T33759851
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
