Question about Home
The pilot light on my FPX 1080cf fireplace lights but there are no flames.
I can hear a faint sound like the igniter might be trying to start but it is faint. I'd like the fireplace to work for xmas and no one can service it until January. Last time it was serviced someone used a brush to clean off the sensor. I wanted to try that but not sure how to turn off the gas feed to the fireplace or make it safe to open and check.
jsrock516
  • 5911 Answers
SOURCE: no heat
You may have a weak igniter. Just because the igniter glows, does not mean it is working properly. The glow bar type igniters are supposed to draw a certain amount of current in order for the gas valve to open. If the current potential is never met, the gas valve will not open. This is a safety feature used to prevent gas flow without ignition. The current readings for the igniters are as follows: Round style glow bar: 2.7 to 3.2 amps Square style glow bar: 3.2 to 3.7 amps If it is reading less than the required amperage, replace it. This may just solve your problem. Let me know if this helps you.
Posted on Sep 08, 2007
  • 82 Answers
SOURCE: Gas Fireplace pilot light continually goes out
You may have a problem with the flame sensing capillary. It may need to be replaced, or it may need to be positioned into the pilot flame better, or you may need a new gas safety valve. Sometime there is an adjustment screw for the pilot which can make the flame bigger or smaller. If will be on the safety valve.
Posted on Dec 01, 2008
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
SOURCE: gas fireplace won't light up even when pilot light is on
Check for how clean the bottom of the unit is. I know it seems small but when dealing with these amounts of electric current they are just that "small" and the dust can be shorting out the unit and not allowing the gas valve to release the gas. Its a safety thing, they dont want gas around an electrical short "go figure" lol
Posted on Jan 05, 2010
SOURCE: My Majestic DVR36RN gas-log fireplace
Majestic DVR36RN: Here's what you need to do: Verify gas line is open. (You said you already have done that). Next turn the switch to pilot (you said you did that too). Make sure wall switch is on also. Now press and hold the pilot switch and hit the ignitor. Once it lights you need to continue to hold the pilot switch for roughly 1 minute. Release the knob and the flame should stay lighted. Now, turn the knob to on. You should be all set now.
Posted on Dec 14, 2010
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
My Insta_Flame gas fire place will not turn off completely. We ahve turned off the gas supply now, but before it still had a tiny flame burning even when turned off.
boy that is one sad excuse for a heating guy. how foes this thing flame on? if it doesn't have an electronic spark start mechanism then it operates with a pilot light that will always be going as it uses this small flame (pilot light) to ignite the gas when the thermostat turns it on.
Nov 21, 2014 | Heating & Cooling
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Feb 02, 2014 | White Mountain Hearth Empire Tahoe 36...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have an Insta Flame Canadian Fireplace Manufacturing Inc. gas fireplace, installed in 1990. The problem is that when I light the pilot light, it will ignite, but it will not stay lit when the knob is...
sounds as though you need to get the thermocouple(copper wire that sits in the pilot flame) replaced, check first to make sure it is tight at the gas valve end, as they can loosen over time due to expansion and contraction.
Sep 06, 2011 | Heating & Cooling
Turned down the fireplace accidently turned it off. The pilot can be pushed in however it is not igniting . Can it be lit manually
If your getting a flame when igniting, and your still pressing in on the pilot then all you need to do is hold it in for about 30 seconds or so. This is because theres a thermal cutout then needs to heat up form the pilot to keep the flame lit.
If you've got no flame at all then you should look at your fireplace manual and see if theres an alternative to lighting the pilot. I wouldn't recommend opening it to light the pilot.
Apr 17, 2011 | Heating & Cooling
Have a GTI Insert Replaced the thermo coupler . Now the pilot light stays lit but when the fireplace starts it will only go for about 30 seconds then you hear a click and shuts down pilot and all.
It sounds to me like you have a bad flame sensor.Luckily most of the time they are pretty easy to change. If you have your manual it will show you the physical location of flame sensor. Usually 1 or 2 screws holding it in place. Remove screws and unplug wires to remove sensor.Install new sensor and hopefully you're in business. Thank you.
Nov 22, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Fireplace will not start. I have not had it lite since last winter. I turn to pilot and wait then hit ignite. I get a spark but the pilot light does not light.
your line mite be stopt up get a mach and turn on you gas and see if i lights up if it dont your eather out of gas or your gas holes whare the flame cums out is stopt up
Dec 16, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Home Logo
19 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
