Question about Comfort Zone Heating & Cooling
Comfort zone radiant heater cz530wm,1week old left it on, unplugged 8 hours plugged back in won't come on. So how do I reset
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Posted on Oct 14, 2008
SOURCE: Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Posted on Nov 20, 2008
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
Posted on Dec 06, 2008
micromatikal
  • 2777 Answers
SOURCE: I have an AO5 error
This indicates a power fault inside the actual heater. Have you tried unplugging the heater, letting it sit for a good 2 minutes, and replugging it back in? If the problem persists you will unfortunately need a repair. Please let me know if you need more information on this. You can also contact comfort zone, the manufacturer, located in Canada, at 780-420-6572.
Thanks so much for the question,
Tim
Posted on Sep 09, 2010
  • 7 Answers
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Posted on Oct 02, 2010
How do I reset my Comfort Zone Heater Model CZ20118
no sign of power ===main power line or power switch may be defective,,,if u want to reset===power offf main power & wait for tan minutes
Feb 20, 2015 | Comfort Zone Heating & Cooling
I just got a life smart infrared heater took it out of the box plugged it in and turned it on and an E3 code is flashing wont turn on or any thing
What is wrong with my Comfort furnace, If it will not turn of when i push the off butting ?And even after that i unplug it and turn it back on ,it still comes on and will not go of like it use to with the temp control !!
Nov 30, 2013 | Comfort Zone CZ1500WC Infra-Red...
Won't heat my studio - even on "HIGH"
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
Jan 01, 2013 | Comfort Zone CZ7007 Oil Filled Electric...
Why does my comfort zone infrared heater shut off after I turn it on? What modes does it have?
What is wrong with my Comfort Furnace heater if i have it turned off and it still keeps blowing ,Yet if i plug it back in it still comes on and i can turn it way down with it down on 55 and it will not shut of like it use to?
Oct 08, 2012 | Comfort Zone CZ1500WC Infra-Red...
What is code A04 and how to fix it?
AO4 is a PCB Board used for some of the Comfort Zone heaters distributed by Earth Wise. Try using the up, down and enter for a reset of the unit. If this does not work unplug and try again.
Nov 21, 2011 | Comfort Zone CZ1500WC Infra-Red...
Comfort Zone CZ 1500 A04 CONTINUES TO COME ON
The AO4 is a board used by Earthwise on the Comfort Zone Heater. The reading is the board being used. If the heater just gives that reading it may need to be reset. This can be done by pressing up, down and enter at the same time. If this does not work unplug and try it again. Hope this helps
May 04, 2011 | Comfort Zone CZ1500WC Infra-Red...
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets...
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Jan 18, 2011 | Comfort Zone Heating & Cooling
Oct 03, 2008 | Comfort Zone Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
