My profile wpgt9150 washer randomly shuts of and will not finish its cycle....even after resetting it rarely will finish a load
SOURCE: Washer won't start; has alternating "dl" and "f" errors....can't reset
I try to restart, but my machine did not lock the door, then can not run as normal, what shoud i do to make them run again
Posted on Sep 29, 2007
localwonder
  • 6784 Answers
SOURCE: washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 26, 2009
  • 194 Answers
SOURCE: At the middle of my load there was stop with code symbol E3
E3 is that the machine can't see that the motor is spinning. Could either be a loose connector at the motor or a loose hall-effect sensor. this might be a fairly easy fix for a repair tech,
Posted on Dec 27, 2009
heatman101
  • 43501 Answers
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 12, 2010
repairman45
  • 130 Answers
SOURCE: the washer will start a load of laundry then about
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Please rate my solution if it was at all helpful.
Thanks, Repairman45.
Posted on Dec 17, 2010
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
Mar 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Why does he GE profile top load washer trip my GFI circut half way thru it's scan cycle
Earth leak either due to water in something or a ground fault in the motor is my guess. It may even be a motor windings fault that is building up resistance as it warms up. You need a service engineer with a good test meter,
Nov 18, 2017 | General Electric Profile WPGT9150 Washer
Washer does not spin, during the spin cycle
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 14, 2011 | General Electric Profile WPGT9150 Washer
I have a GE Profile top loading washer mdl # WPGT9150 and I have a question about a problem I am having with it. The washer stops halfway through the wash cycle and the electronic board flashes E4, and I...
E4 is an error code indicating a problem with the water inlet valve or the electronics that control the inlet valve. Error codes do not necessarily indicate the problem directly.
Here is the service manual (with diagnostic procedures) for your machine:
http://www.geservicenet.com/cc/trngprog/ProfileWasherWPGT9150.pdf
Good luck.
Mar 01, 2011 | GE Washing Machines
GE Profile WPGT9150 will not start cycle
You have a bad transmition.
Please rate this solution
Aug 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
Mind of its own
THE ONLY RESET IS TO UNPLUG IT FOR 15 MIN. SOUNDS LIKE MAIN CONTROL BOARD BAD
Oct 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
