Question about Health & Beauty
Have hoverround been in storage and tyring to charge
Have hoverround been in storage and tyring to charge not working no lights help
  • 103 Answers
When the batteries sit for more than one month without being used they die. You need new batteries. The batteries are a 12 volt deep cell. U-1
Posted on Jul 23, 2009
What's the tyre pressure for a caravan with 185r14c on it
It depends upon the type of tyre, whether you have a single or dual axle as well as the weight of the van when loaded.
The maximum tyre pressure for the type of tyre you have will be listed on the sidewall of the tyre. Given the weight of a loaded caravan I would recommend you run the tyres at 2 PSI under the maximum pressure listed on the tyre for a cold inflation. If the maximum is, say, 40 psi then run the tyre at 38 psi. Tyre pressures will increase when the tyres are warmed up from running so always check and adjust the pressures when cold and purchase a good tyre gauge to carry with you if you do not have one yet. Higher tyre pressures within max specification, will lower the tyre's rolling resistance and tyre heat build up, places less stress on the tow vehicle and will give better tyre life on the van tyres.
Tyres are maximum load rated so know the van weight and make sure you do not exceed the load limits of the tyres (printed on the side wall) when adding weight to the van, including water storage.
Tyre Sidewall Explained
Jun 06, 2016 | Cars & Trucks
Tip
Slicks, Semi-Slick OR Knobbly Tyres, Oh what do I use for my MTB !
A SLICK TREAD MEANS THE TYRES ROLL BETTER ON THE ROAD
A SEMI SLICK TREAD MEANS THE TYRES ROLL WELL ON THE ROAD, BUT CAN ALSO BE USED FOR LIGHT OFF-ROADING, A COMBINATION OF SLICK ACROSS THE CENTRE KNOBBLY ON THE EDGES
A KNOBBLY TREAD MEANS THE TYRES ROLL BEST FOR OFF-ROADING THIS IS A STANDARD MTB TYRE, AND GIVES THE BEST TRACTION IN THE MUD.
THERE ARE TYRES THAT CAN FOLD FOR EASY STORAGE AND REPLACEMENT IF YOU HAVE A BLOWOUT AND ONES THAT DON'T THAT WILL LAT LONGER DUE TO INCREASED WALL THICKNESS IT ALL DEPENDS UPON THE USE.
FOR THE ALLROUNDER THE STANDARD NON-FOLDABLE SEMI-SLICK MAYBE THE BEST OPTION
on May 19, 2010 | Cycling
Hello, changed a flat tire on hoverround and when i went to turn on to go....the lights were flashing on the left arm rest area?
Check the freewheel lever in the front of your chair If it is freewheel then thats the cause of the lights flashing other than that you don't give too much more info to be able to answer your problem Hope this helps
Mar 28, 2011 | NRS Hoveround MPV 5 - Used Power...
I am leaving my kawasaki balius for 2yrs w/out running,because i have to work abroad.I need a suggestions on how to preserve the engine in good shape,and to escape from overhaulin the engine.Highlly...
If you can leave it in dry storage, remove the battery and put it on trickle charge or better still get someone to trickle charge it once a week for you for a few hours or until it is charged and reads 13.6Volts.
The rest will wait.
When you return, change all the fluids before trying to start it, including break and clutch fluids!
The battery should survive and that will be that. A bit of a polish, check your tyres and off you go.
Mar 12, 2011 | 1997 kawasaki Balius - II
Used hoveround power chair
mcdevito75 here, The control switch could be bad, Contact Hoverround online at Hoveround .com You can also check with any Medixal Supply store in your area.
Jun 20, 2010 | NRS Hoveround MPV 5 - Used Power...
Have a hoverround mpv 4,do you charge with the controller on or off,when on i get a buzzing noise loud im thinking you charge when the controller is off need help thank you
Typically you will charge with the controller off, but it is not critical. The buzzing noise may be the fan on the charger, which is normal. Make sure the silver handle of the charger is fully inserted into the controller. If the light on the charger is on, you have kept the charger connected for 8-12 hours and still the batteries will not charge, there may be a problem with the batteries being bad and they need to be replaced.
Jan 15, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
I have a mini one D & cannot find the book - round dashboard control has 7 circular lights above speed controls - the 2nd one in from the right just turned red when I was on my way home from work - its...
its your run-flat tyre light.. it means you might have a flat or deflated tyre, but if all your tyres seem fine it could be your ABS system, get it checked by an auto electric guy as opposed to a mechanic - advice: dont go to the dealer!!! they are a rip-off...
Nov 22, 2009 | 2007 Mini Cooper Convertible
HAVE A HOVEROUND
Carefully read across two pins, without shorting to the case or other pins. You should have 1 hot, one ground, and usually another ground that acts as a charge inhibit to keep the scooter from driving while charging. I would expect to see around 27 Volts DCX on the output, maybe more without a load attached (battery)
Jan 25, 2009 | Electric Mobility Power Electric Scooter...
Health & Beauty Logo
157 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
