Question about Comfort Zone Heating & Cooling
How to reset a ,cz530wm comfort zone radiant heater
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
Posted on Dec 06, 2008
shastalaker7
  • 1515 Answers
SOURCE: cz 446 comfort zone ceramic heater shuts off
Hi, the problem you are having is the thermostat control, and dimming the lights is a indication of the neutral side of the control if faulty.It is drawing enough amps to make you're home lights blink, so I would stop using it now and if you are inclined to replace this control yourself I would. If this is something you would not care to take on, I would get an estimate for repair at a appliance repair store, compared to replacing the unit with a different one.I am sorry to tell you this, but it will only get worse and what I have recommend is for you're safety.
Sincerely,
Shastalaker7
PS Please keep me informed of the situation, as I would love to be of any help you may need.
Posted on Dec 05, 2009
  • 7 Answers
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Posted on Oct 02, 2010
  • 13 Answers
SOURCE: my comfort zone heater wire element is glowing and
dust and dirty air can be one problem or some object has fallen in to it you may need to get it cleaned
Posted on Nov 29, 2010
  • 383 Answers
SOURCE: Is there a recall on
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
Posted on Jan 15, 2011
Tip
Radiant Heating - Why do You Feel Warm? The Best Most Efficient Heating System
What makes you feel warm on a sunny day in the summer? Radiant heating or radiant energy is usually recognized as the oldest form of heating. It provides the best comfort and is the basis for all types of heating systems. Radiant heating is "radiant energy" being emitted from any heat source. Radiant heating is the effect you feel when you can feel the warmth of the sun or a hot stove top element from across the room.
Radiant heat is widely known as the most comfortable and efficient heating method you can find. Some of the advantages of radiant heating are: it is usually more efficient than baseboard heating and almost always more efficient than forced-air heating because no energy is lost through ducts and other transfers. This technology can be used for both heating indoor and outdoor areas. These heating systems work by supplying heat directly to the floor, to panels in the wall or to the ceiling of a house. Because the radiant heating will make you feel warmer when you are in a room, you can have the thermostat at a lower temperature and still feel warm.
The feeling of warmth is the absence of heat being pulled from your body. If the walls, floors, and ceilings around you are warm then they are not pulling heat from your body. Then you feel warm. Your body is not giving up heat to them.
Because of this radiant heating systems can provide massive energy savings of more than 10-30% in most residences, and sometimes up to 60% in shops, hangars and warehouses. Radiant heating provides even warmth with no cold spots within a room. That provides a comfortable environment that cannot be matched by any other type of heating system.
New radiant systems are currently designed to run cooler than they did in the past. The water supplied to the systems will generally range from 90 to 140 degrees. Remember radiant heat can travel in any direction and is unaffected by gravity. Radiant heating systems will allow you to be more comfortable at a lower thermostat setting. Radiant heat will warm the closest and coldest mass, which then radiate heat throughout the space evenly. Radiant heating will give you the most consistent room temperatures from floor to ceiling when you compare it to any other heating system.
on Dec 12, 2009 | Heating & Cooling
How do I reset my Comfort Zone heater?
The top light is coming on but the fan isn't working
Feb 20, 2015 | Comfort Zone Heating & Cooling
How do I reset my Comfort Zone Heater Model CZ20118
no sign of power ===main power line or power switch may be defective,,,if u want to reset===power offf main power & wait for tan minutes
What is code A04 and how to fix it?
AO4 is a PCB Board used for some of the Comfort Zone heaters distributed by Earth Wise. Try using the up, down and enter for a reset of the unit. If this does not work unplug and try again.
Nov 21, 2011 | Comfort Zone CZ1500WC Infra-Red...
Comfort Zone CZ 1500 A04 CONTINUES TO COME ON
The AO4 is a board used by Earthwise on the Comfort Zone Heater. The reading is the board being used. If the heater just gives that reading it may need to be reset. This can be done by pressing up, down and enter at the same time. If this does not work unplug and try it again. Hope this helps
May 04, 2011 | Comfort Zone CZ1500WC Infra-Red...
Is there a recall on the Comfort Zone CZ7007 heaters? I have two that do not work.
Tell us more--
Mack B
Jan 15, 2011 | Comfort Zone CZ7007 Oil Filled Electric...
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Oct 03, 2008 | Comfort Zone Heating & Cooling
Heating & Cooling Logo
134 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
