My Dell inspiron 1520 has been running slower for a few months now, however now when i load WoW it funs like normal for a short time and then the Fps crashes. When this happens Videos and anything graphical has very low fps. When i restart my laptop it works fine again until i use something graphical
  • 1 more comment
  • mike_peac0ck Jul 21, 2009
    I have the most up to date drivers and i have a cooling pad for my laptop, not sure if its an overheating issue
    Vista
  • ashukla3416 May 11, 2010
    wat os u use
Right click on desktop =>personalize=>display(bottom)=>make low resolution to high
Posted on Jul 23, 2009
    Master:
    Sergeant:
  • 226 Answers
Check to see if your video card has the most upto date drivers if they are you may need a new video card
Posted on Jul 21, 2009
    Novelist:
  • 112 Answers
It almost sounds like your graphics card is overheating or causing your system to overheat after a while of playing. This would definitely cause your computer to slow or even come to a halt.
Try cleaning out the dust and make sure the fans are running well. You may have to add more fans or replace the ones that are in there. Also, if you are using the computer in a hot environment, you will need some other source of cooling the components such as liquid cooling.
I hope this helps :)
Best Regards,
James
How do I down load pics to a memory stick I use a dell inspiron 1520
The download procedure is the same but while saving choose the location as your memory stick.
Jun 21, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
My dell inspiron 1520 does not work at all, power
no this is not a defect this would indicate that the power supply has failed on your pc.. look at the back of the unit if the power supply light is amber in color or blinking thne there is your issue.
May 13, 2010 | Dell Inspiron 1520 Motherboard
Inspiron 1520-before finishes loading desktop screen goes black..
if it works fine in safe mode you should try a system restore . most of the time a problem that gos away in safe mode is driver related . IE software don't think you have a hard ware issue. you can call dell if you do not have the disk . 1-866-751-6079 call this number it's dell's Spanish tech support number but this is the fastest way to reach a real person at dell . just ask them to speak English and they will.
May 12, 2010 | Dell Inspiron 1520 Motherboard
My dell inspiron 1520 does not work at all, power light is on for few seconds, then nothing happens, is this a factory defect?
have you tried chsrging it up by plugging in for a long period, make sure the cable to the transformer is actually plugged in securely they tend to work loose and look okay but arent.
Mar 21, 2010 | Dell Inspiron 1520 Motherboard
As it works ok in safe mode, I suggest you check that your graphics drivers are up to date.
You should be able to download the latest from the Dell website.
Mar 20, 2010 | Dell Inspiron 1520 Motherboard
My Dell Inspiron 1520 will not load anything past the first Dell screen. It loads Dell then goes black with a flashing cursor in the top corner, I have tried pressing F8 to do a system restore but it never...
Hello, Beth.
The most common reason is memory. Try reseating (remove and reinsert) the memory, first.
Power off the computer and disconnect all cables. Flip the laptop to the back. Remove the battery. The memory cover has 8 screws. Remove the memory modules at a 25 degree angle and reinsert them by pushing them down firmly by the ends.
If reseating the memory doesn't solve your problem, one module may be bad. So, remove and test each module one at a time.
Hope this helps.
Nov 23, 2009 | Dell Inspiron 1525 Notebook
My screen on my dell inspiron 1520 has gone black
You've lost your desktop display.
The first thing I would do is to start the computer in safe mode. Once there, do a system restore back to the time that it worked.
I would also, just to be safe, do your disk management tasks like checking your hard drive for errors and running defrag.
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
Inspiron 1520 screen has gone dark It is displayed on an attached monitor so the problem is not with the vidio card
Well, look for the Fn button after logging on your compute. this button is normally on the left bottom of the keyboard, press it continuously then press the F8 button once,twice if there is no change then three times if it fails again, remember not to releases the Fn button while doing this.
Oct 15, 2009 | Dell Inspiron 1520 Motherboard
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
