ISymphony M110 no workee
It just went dead, sometimes the standby light will come on, but nothing else
The first question we need to look at is does it still have a warranty?
If not, then have fun.
I did this for my son a couple of months ago.
1. Unplug the unit from it's power source.
2. Remove the back cover and one side cover, opposite the power cord.
3. There are 3 fuses, one located next to the cable inlet and on the right side there are two more, one for each speaker.
4. If you only replace the one fuse, the power may go on, but there might be no sound.
Try it and see.
If there is still no sound, you need to replace the other two.
They are hard to see.
You can get these at any hardware store and replace them yourself.
Posted on Sep 23, 2009
  • carly-nan Sep 12, 2010
    I could only find one fuse inside, but clearly it was burnt. Will get a replacement
When i turn on my ispymphony 32 inch nothing comes on
The fluorescent ballast has taken the proverbial dump. Take a light and look at the screen closely from different angles. See if the menu from the remote is in the darkness of the screen. If so, your backlight went out, or at least the capacitors that fire it. Get a new unit unless you know electronic repair.
Nov 16, 2013 | iSymphony LC32IH60 TV
Wharfedale dvdr24hd169f stays in standby no displays wont accept commands
The problem is in the power supply board, often caused by a defective capacitor that becomes open, cap value is usually around 1000uf and sometimes shows a bulge at top leaking contents, if you are handy with a soldering iron replace part with identical value and voltage rating and observe the polarity.
Jun 09, 2012 | Wharfedale Televison & Video
ISymphony LC22iH90 22 LCD TV just black screen
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_2_04_52_pm.jpg
Look inside at the power supply board to see if puffed up caps like these.
Apr 02, 2012 | iSymphony LC22iH90 22 LCD TV
Actually iSymphony M110 - it doesn't wont to turn on. Just the stand on red lamp is on and no response on any buttons. Does it has sort of reset button or it should be repaired in service center? Do you...
I just bought one of these "dead" units for $15...I replaced the blown 2A 250V fuse with a new 2A fuse and it blew as soon as I plugged it in so then I took one of the 4A 250V fuses from the other side of the unit(located right behind the speaker output terminals) and it works perfectly now.
Sep 18, 2010 | iSymphony M1 Shelf System
Standby power red light is ON, and system not powering up
This is happening to me too now. Help would be great!
Aug 06, 2010 | iSymphony M1 Shelf System
Insignia ns-pdp50hd: power went dead, no standby
This could be your Power Supply Module or your Main board. I suggest taking it in for a diagnostic check.
Nov 17, 2009 | Televison & Video
Samsung ps42a456p2 (42 inch plasma) won't power on, stays standby
i'm pretty sure the power supply board is dead. the most common problem with all samsungs.
Oct 30, 2009 | Televison & Video
Sony PFM-42B1E plazma screen
Does the red standby light flash ?? If so count the flashes and see my error code section.
Jul 05, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
532 people viewed this question
 Grubhead
Grubhead
