Question about Simpson Washing Machines
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Simpson 9.5kg
    Habit-Forming:
    Scholar:
  • Simpson Expert
  • 170 Answers
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Posted on Dec 26, 2016
Hi,i have a Simpson EZI Sensor 6 kg top load it has PU error code, any one knows what this code reflects? Thank you in advance Mike
It means pump error. Water is slow to drain or not draining at all. May be a blockage or could be a faulty pump.
Dec 06, 2016 | Simpson Washing Machines
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
Nov 13, 2016 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Simpson washing machine error message e20
i am having a problem with it draining, it turns and washes though, where is the filter?
Sep 29, 2013 | Simpson Washing Machines
SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
Simpson error code 5p
I have a error code Ld come up on my Simpson eziset 5.5 kg top loader washing machine what does that mean ? Also is it possible to replace a sensor battery for that. Model and what size battery replacement do I need to ask for
Feb 23, 2011 | Electrolux Washing Machines
Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Jul 06, 2009 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
