Question about Stihl Garden
Tore the saw down two wheeks ago got the parts for four the saw four got where the whires go on coil. And the switch stihl 021
  • 43 Answers
I believe you have 2 wires apart from the ignition wire to the spark plug. The black one goes to the on/off switch and the yellow / green goes to earth and is normally attached to a screw near the ignition module - one that fits into the metal body or the engine lump.
Posted on Jan 03, 2017
  • 666 Answers
SOURCE: stihl 021 running poorly
Couple of things I would check first. Place a funnel in a can with a paper napkin covering bottom of funnel. Pour the gas from the saw into the funnel. If there is a lot of trash in there, remove the fuel line from tank. Clean the filter with carb. cleaner. Then clean the tank with carb. cleaner. If you still have problem. Replace the Air inlet tube, (clear tube with screw type device close to carb).
Posted on Apr 16, 2009
dontbother10
  • 2220 Answers
SOURCE: I need a repair manual for stihl ms192t chain saw for down load
Stihl considers ALL IPLs and shop manuals proprietary.
Every time Stihl becomes aware of an on line source they force its removal.
Rules here prohibit any expert from providing you an e-mail address, if I had what you seek I cannot provide a link where you can get it.
You can go here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A large international collection of chainsaw enthusiasts, sellers and mechanics. Not only can you find what you seek you can find someone that has already done it, experienced the pitfalls you will meet, and overcome them. Please do a few searches before posting any question. Joining an existing thread is almost always more fruitful than posting the 4th, 5th, 6th question all asking the same question. HTH
Lou
There are many threads pertaining to Stihl, many also discuss overhaul of different Stihl models. Good Luck
Posted on Feb 04, 2010
Testimonial: "I THANK YOU FOR THE EXCELENT ANSWER. I WILL TRY YOUR SUGGESTION TO SEE WHAT HAPPENS SEEMS LIKE A POOR WAY TO RUN A BUSSINES. GEORGE"
dontbother10
  • 2220 Answers
SOURCE: no spark what are the ohms specs on this coil this
Answered in clarification.
Posted on Mar 06, 2010
fixya167
  • 119 Answers
SOURCE: my stihl saw will not spark
kill switch wire short to earth on casing or coil open circuit Re: Jeff
Posted on Apr 12, 2012
philwalker78
  • 608 Answers
SOURCE: which is more reliable..a stihl 017 or a stihl 021 ? looking to bid both in good runnung shape...thanks
Hi, you cant go wrong their both stihls. The 021 is a more powerful saw and the 017 is lighter, so it all depends on your intended use. Regards Phil.
Posted on Jun 27, 2012
What causes 021 stihl saw to cut off?
Your chainsaw is running-lean, take off top cover. You should see the air filter. Under The plastic air filter housing is too nuts, 12mm socket is Wot you need next, you need to check these too nuts are tite, these nuts hold the carby to the Intake, all air that goes into the saw is mixed by the carby with fuel. Your saw is running lean. So if those bolts are tite you'll need to check the gasket between the carby and the block....... There are others possibilities but these too are your most likely.
May 03, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
BROKEN SPARK PLUG IGNITION WIRE
If the lead is broken, depending on which saw it is, you can buy a replacement lead. Unscrew the wire from the ignition module and screw in the new one after you put the end and boot on it. If it doesn't unscrew then you will have to buy a new module
Nov 03, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Which is more reliable..a stihl 017 or a stihl 021 ? looking to bid both in good runnung shape...thanks
Jun 26, 2012 | Garden
Have a lose wire on a stihl 021 chainsaw by air filter but don,t know where it goes to
It probably goes to the ground on the choke lever. Remove the air filter and look at the area where the shut off switch is located, you should see a small slot where the wire slides in and connects with a metal piece in the stop position.
Apr 05, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
My 330 homelite is shocking me
your new coil may have a crack or some kind of a electrical leak, replace it and go from there
Apr 25, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Homelite 330 shocks me when running
Check your wires, sounds like a grounding issue.
Stihl 021 running poorly
Apr 15, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
96 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
