Question about Refrigerators
New Hisence fridge freezer noisy and hot - Refrigerators
  • Refrigerators Master
  • 5,323 Answers
For the noise check the compressor groumits
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
the reason the outer side of the door seal area is getting hot is the compressor is over heating, probably the condenser fan motor to your compressor is bad.
It should be a little warm but not hot. they don't use heaters anymore ( some older models still use heaters) around the doors, instead they use the condenser coils to remove condensation and moister, you might want to check your condenser coils on the bottom or back of fridge to see if they need cleaning
If the condenser coils/condenser fan are all plugged up they need cleaning and/or the condenser may fail or has failed..
The ones that use an electric heater will have an "energy saver" switch that will turn it off.: God is the reason I give you free advice so God is good!
Posted on Dec 27, 2016
3 Suggested Answers
  • 5 Answers
SOURCE: Noisy compressor on fridge freezer
does it always make that hum noise or just when adjusting temp
Posted on Aug 18, 2012
  • 40335 Answers
SOURCE: Why is there no sign of a drain hole in my fridge part of the fridgfreezer
The drain is in the bottom of the freezer section
Posted on Oct 16, 2016
Check the position of the Fridge. It sounds like it is not level. Most fridges have adjustable height feet that will allow you to level the fridge. That may be your issue since the water cannot flow where it needs to. Put a stick level on top and adjust the feet until its level frnt to back and side to side.
Oct 16, 2016 | Refrigerators
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
I've problem my fridge make it noise & ice
please provide make and model number of the fridge.
also what is the problem. Is it too noisy in operation and there is lot of ice in freezer.
Check the freezer door seal has not come off and the compressor at the back is not too hot.
Oct 13, 2011 | Refrigerators
E440t water pooling inside roof of fridge. then it leaks into fridge when its full. fan was noisy, now not making much noise. maybe its stopped.
THE drain in freezer is frozen over and the water is leaking into the fresh food / clean drain with hot water and turkey baster . this wil correct problem . some units need a drain heater installed to prevent it from doing it again .. mm
Aug 11, 2010 | Refrigerators
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
LG GC299BA Fridge working but noisy, freezer broken.
It sound rather like one I used to have (but worse) which was never 100% satisfactory. When it eventually failed we called in a repair man who said it had been faulty since it left the factory.
I advise you to scrap it and but a new one. If you have any similar problems with new equipment, go back to the supplier within the warranty (if you have an extended warranty, then call them out now!).
Jan 23, 2010 | LG Refrigerators
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Feb 15, 2009 | Maytag Refrigerators
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
