Question about Fargo Office Equipment & Supplies
I'm having a problem with a Fargo c30 where I can print test prints just fine but trying to send any custom job will result in wierd prints. It basically just prints a multitude of random colors.
SOURCE: prints black on test page, but not when a job is sent to the printer
I just posted and also fixed my problem. Try "deep cleaning" under the maintenance tab. Choose the black cartridge only. Mine only took once to fix but i'd try it 1-3 times before giving up on this solution. It now prints the test page with black and color
Posted on Nov 19, 2007
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Posted on Oct 28, 2008
SOURCE: HP Color LaserJet 4600 Keeps Calibrating
Replace the Jet direct card in it. I had a similar problem and replaced the Jet Direct card, all was good never had that problem again.
Posted on Apr 28, 2009
  • 526 Answers
SOURCE: Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
Posted on May 31, 2009
komguy
  • 2306 Answers
SOURCE: Canon Pixma ip1500 is printing but very wierdly.
Your printhead is plugged and needs cleaning. If you remove the inks and then the printhead, you can wet and fold a paper towel and just dab the printhead gently on the wet towel. When you see a solid black line on the paper towel your printing should be improved.
Posted on Jun 23, 2009
Why my persona c30 fargo breaks all ribbons installs Thanks
Mind the printing ofset settings, colour intensity as well!
Aug 07, 2011 | Fargo Persona C30 Thermal Card Printer
Why is the plastic card becoming jamed in the middle of the printer, it will go forward and reverse though
Really disappointing to hear that. All you need is proper guidance of handling printers there can be some technical issue with the printer. I heard of Plascards engaged in printing of plastic cards may be they can help you. You can also get it printed from this firm or can take assistance from other who have overcome such issues. Hope you get a proper solution soon. Plastic Cards and Custom Gift Cards Printing
Feb 26, 2011 | Fargo Persona C30 Thermal Card Printer
Persona C30 Thermal Card Printer: im using fargo printer 30e. everytime i tried to ...
How many prints have been down on the unit?
the most common problem could be the rollers need replacing or a problem with the ribbon sensor. We do repairs and also repair under warranty, How old is your printer?
thanks
May 16, 2010 | Fargo Persona C30 Thermal Card Printer
It prints the yellow & magenta layers, then skips printing cyan & black (with screeching noise as the ribbon passes) to printing overlay (sometimes skips overlay), but stopped short of ejecting to...
Download the latest copy of the C30 firmware, Fargo created a fix by sending more power to the ribbon sensor. After downloading the new firmware, calibrate the ribbon covering the printer the best you can from light.
Nov 18, 2009 | Fargo Persona C30 Thermal Card Printer
Ribbon keeps breaking - cards get stuck, or cards come out in funy colors
try to run the diagnostic utility as instructed
clean the printing path by fargo cleaning kit
Nov 17, 2009 | Fargo Persona C30 Thermal Card Printer
FARGO c30 Won't print, gives following error message run time error -2147417848 (80010108) Automation error. the object invoked has disconected from its clients
You have not mentioned the application you are using.
This is probably not a problem with the printer. this is mostly possible due to macros in the application through which you are printing the cards
try to find out if any patches available for your application.
Also try to install your application again after doing uninstall of the same.
Hope this will definitely solve your problem. Do remeber to run microsoft update for your operating system
Oct 23, 2009 | Fargo Persona C30 Thermal Card Printer
Fargo P C30
you probably have a scratch on the printhead.
Mar 14, 2009 | Fargo Persona C30 Thermal Card Printer
Card printing
It sounds like a printhead pixel has burned out. The only fix for it is to replace the printhead.
Aug 21, 2008 | Fargo Persona C30 Thermal Card Printer
Is there a fargo certified service center in the Seattle or surrounding areas?
You could look at Fargo website www.fargo.com to find service center neer you or call customer service they will help you Number on website
Aug 06, 2008 | Fargo DTC525 ID Card Printer
New ctg. change problems
In the printing preferences there is an auto detect ribbon button . you should select it.
Your ribbon will be updated. Also if printer asks you if the ribbon is correct select yes. The printer will then print on whatever ribbon you have intalled. This doesnt work with test prints
Dec 26, 2007 | Fargo Persona C30 Thermal Card Printer
27 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
