KV-32HS420 sony tv thay the stand by light blinked 7 times before repairs. I have replaced the IC6501 & IC8002. Now it blinks 6 times . Can some one tell me what to do next. I have a service manual for this unit & I am an electrician. Very handy with my tools and can perform some repairs. Please advise
  • 5,807 Answers
first we start with the power supply,
we need to have at least 110v to have the deflection circuits working.
if you have a multimeter measure the voltage on the capacitor after the diode of chopper secondary windings.that would be the B+.
maybe the supply rail B+ is only about 45V or still lower
solution : replace the horizontal deflection flyback transformer maybe partially shorted
maybe no voltage at all
solution : check horizontal output transistor might be defective, replace if found shorted
maybe there is a good supply say at least 110V , but no oscillator drive on the horizontal output transistor, or blocked oscillator signal drive
hope this helps, thanks for using Fixya!
Posted on Jul 21, 2009
I have a Sony Vega KV 32HS420 it will not come on and bliniks 6 times. what is up?
Try replacing IC8002 and IC6501 (MCZ3001D).
Hope this helps.
Apr 07, 2011 | Televison & Video
My sony wega 32hs420 timer light is blinking 7 times stops then blinks 7 times and so on. do i need a repair man to come look at it?
Yes,this problems must have parts change.Repair and parts should be under $250 more than that not worth it to repair old CRT tube tv.High Voltage parts are dead must get it replaced.
Jan 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My tv will come on with no picture but with sound. stay on for a few seconds then turns off and the stand by light flashes 7 times
If no HV, ic8002 is bad part# MCZ3001DB beside flyback transformer. I usually replace IC6501(regulator driver) and IC8002 at the same time, they both have the same part number. If you are not a technician think twice first before replacing because you need a very good soldering skills.
Dec 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Nov 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Light blinks 6 times, no picture, no sound
6 times blinks shows error of Low +B, OVP/ OCP
Replace IC6501 & IC8002 [ MCZ3001D ] on D board.
If you are handy with electronics stuff repair and can solder parts in circuit board then replace above said ICs or call local TV tech to do the job.
Thanks.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV turns off and the standing timer light blinks.
There is a timer option programmed into your set. Check the timer setting in menu, under advanced settings
Sep 16, 2009 | Televison & Video
Sony KV-32HS420 won't come on.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 02, 2017 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Kv-34hs420 Standby light blinks 6 times. Power supply issues?
Replace IC6501 and IC8002 at same time, both have same number and located parallel on DZ board. Part number is as follows..
670581001 MCZ3001DB
Available in Part Store.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Kv 32hs420 7 slow blinks form the led light sounds comes on but no picture shuts it self down then give me 7 fast blinks hhhhhheeeeelllppppp
The slow blinks are normal at startup. The quick seven blinks indicate that a problem was detected and the set is shutdown to prevent further damage. I'll look up your model later today and post the probable defective parts. Are you planning on attempting the repair yourself?
Dan
Mar 10, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kv-40xbr800 won't turn on, blinks 6 or 7 times
there are two large electrolytic caps on the D board located on the same side as the hv xformer.
both caps are 1200ufd at 250v, replace C6503, it is futher away from the side of the pcb.
this is the part of the ac rectifier that feed IC6501 chip MZ3001D
cap size is 1 1/8" diameter and about 2" inches high.
my problem with 6 or 7 blinks, would go away temporarily after the tv was unplugged for 24 hours.
i verified the fix by attaching a 250ufd at 250v cap in parallel with the C6503.
the problem was corrected.
you must assume the cap is leaking, which leads to the intermittent failure.
parts and shipping are a killer, so i turned to ebay.
search ebay for "Electrolytic Capacitors, 1200 uF, 250 Volt, Snap in 2X".
as the only bidder, i picked up two caps for $3.99 + $3.50 s&h.
might be wise to replace both caps, C6503 and C6590.
bill wireman
Feb 16, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Televison & Video Logo
Top Televison & Video Experts
