Question about Vacuums
Hello i have a question about my nimble. i plug it in to vacuum and i have it on carpet mode. when i go to vacuum the brush spins but it has no suction and sounds more quiet then i think it should.
reddevil6
  • 1673 Answers
SOURCE: Suction only works using the hand held mode, there is no suction when try to use on carpet mode,
There must be a clog in either the hose, dirt inland by the brush roll, or bad filters. If you have suction at the end of the hose, then look lower all the way to the brush roll.
Posted on Mar 25, 2008
SOURCE: The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Posted on Mar 14, 2009
SOURCE: In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Posted on Jun 26, 2009
VacuumRepair
  • 438 Answers
SOURCE: Riccar 8700 Brush Roll
Greetings,
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unpluged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unsrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift staight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, posistion the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the Thumbs Up Icons in the lower right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris Jones
Posted on Mar 21, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: brush inside main head doesn't spin, and stops
    Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 12, 2011
    Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
    See if the following information can help.
    CARPETS OR HARD FLOORS
    • The brush bar will always default to 'ON' (spinning) each time you switch the
    appliance 'ON' and recline it for cleaning.
    • The brush bar will not rotate when the appliance is upright.
    • To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
    - switch the appliance 'ON'
    - recline the appliance
    - press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
    • The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
    clearing obstructions'.
    • Before vacuuming your flooring, rugs and carpets, check the manufacturer's
    recommended cleaning instructions.
    • Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
    happens, we recommend vacuuming in 'hard floor' mode and consulting with
    the flooring manufacturer.
    • The brush bar on the appliance may damage some carpet types. If you are
    unsure, turn 'OFF' the brush bar.
    Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
    Why is my Shark nv500 vaccum carpet brush is not spinning?
    I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
    Aug 01, 2014 | Shark Rotator Professional Lift-Away...
    My vacuum doesn't have any suction from the floor, only from the handheld attachments. I've cleaned all of the filters with no luck. Any suggestions?
    With the vacuum plugged in and running, make sure the brush is spinning and that the brushes on it and long enough that they brush against your hand (or in real terms your carpet). If it is not spinning, replace the brush roll. This will also drastically increase the cleaning ability of it since the new roll will spin faster and the longer brushes will agitate your carpet better.
    Let me know if you need more help,
    chis
    Jun 10, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
    Brushes don't spin
    Hello :
    try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
    or try this also if the above suggestion didn't work :
    Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
    please rate !
    May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
    Hello :
    Try this please :
    Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
    Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
    Try this also please :
    Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
    1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
    2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
    Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
    3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
    4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
    5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
    Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
    6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
    PLEASE DON'T FORGET TO RATE !
    Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
    Brush will not spin
    Hello :
    Try this: switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
    PLEASE RATE !
    Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Dear Expert, the vacuum is not working in normal mode but if i use pipe then it works. Any suggestions? thanks khangee
    So usually when an upright vacuum works well when using the attachment hose, but doesn't work well when vacuuming on the floor mode, this typically means that you have a belt problem. This is very easy to diagnosis. Turn the machine sideways so the brushes are facing you while the machine is plugged in. Be careful and make sure there's no hair, or clothing near the brushes, and turn the vacuum on. When you do this, are the bottom brushes spinning? If the brushes are spinning, with the vacuum running, put the vacuum brushes down on the carpet as if you were vacuuming, and listen to the brushes. Can you hear the brushes stop when you put the vacuum brushes on carpeting?
    If your brushes are not spinning, or if you the brushes stop when you put the vacuum down on carpeting, this is a clear sign that you have either a stretched, or broken belt. Many people equate a broken or stretched belt to loss of suction because without the belt, the vacuum really can not pick up much at all off of the floor. When the vacuum doesn't pick up, many people assume the vacuum has lost suction.
    Your roller brush may or may not also be bad. Installing a new belt properly will help you answer this question.
    Please see the link below for the owners manual to a model that's similar to the model you posted this repair question under. The belt change will be identical. The belt change instructions starts on page 13 of the .pdf
    http://www.hoover.com/pdfs/manuals/C1414900.pdf
    I hope that this information was helpful to you, if so please be sure to rate my repair as helpful by clicking the thumbs up icon in the top of the repair.
    If the belt is fine on your vacuum, please also let me know by leaving a comment here on the repair page, I can then go through some more advanced troubleshooting with you.
    Thank you,
    Chris J.
    GoVacuum
    Apr 06, 2010 | Hoover Elite U5061-900 Bagged Upright...
    My Sanitaire vacuum is not picking up well - works ok on floors but not on carpeting
    Depending on the model you may have a single or two motor system. If it is not running well in carpet mode but still has suction check to see if the brush for the carpet head is turning. If not look for a red reset switch or spin the brush when the vac is shut off. It it spins freely the belt is either broken or badly stretched and needs replacement.
    Sep 05, 2009 | Vacuums
    I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
    The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
    Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Bissell 9200 Proheat 2x carpet cleaner
    cleaner will not start
    yes, I plugged it in!
    Aug 07, 2008 | Bissell 9200 Upright Vacuum
    Vacuums Logo
    26 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
