I've got a independent +C24 boiler and it is now flashing F1 it is nearly at the bottom of the pressure gage andvive no hot water or heating can I do anything shall I bleed radiators
    Master:
  • 946 Answers
How old is it? Under warranty? don-ohio
Posted on Dec 28, 2016
kma836
  • 7 Answers
SOURCE: boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Posted on Oct 18, 2008
  • 68 Answers
SOURCE: boiler keeps losing pressure when the heatings off
Hi Leehardcast,
Yes the problems are related. The system is low on water. So now instead of water you have air in radiators which is easily compressed when it heats up. Then pressure loss when it cools down.
Add some water to your system until you have 15lb pressure and bleed out upstairs radiators at the same time.
Please rate this response and Good luck, Phil
Posted on Jan 14, 2009
  • 70 Answers
SOURCE: Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: ideal c24
sounds like the gas valve to me you need to see if the appliance is sparking 1st if it is then u need to check wether there is the right voltage going to the gas valve according to mi manufactureres instructions normally 240 volts ac if there is voltage then the gas valve is sticking get back to me after your findings
Posted on Jun 11, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Slightly high pressure in C24 Heatline Boiler
my heat line capriz 25 boiler is flashing that i have flam or gas falure and has stoped workin? what do i do?
Oct 05, 2008 | Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
