Question about The Home Security
Trying to install camera with audio to the excisting dvr getting just static..all other 7 cameras ok.
yooperbud
  • 8637 Answers
SOURCE: Bad Static on the Audio
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Posted on Feb 04, 2009
yooperbud
  • 8637 Answers
SOURCE: static audio on GigaWare VGA PC Camera
Posted on Apr 29, 2009
YaBaPortugal
  • 123 Answers
SOURCE: DVR camera system help
First, check what ports the DVR system uses, in GeoVision for example is:
80, 3550, 4550, 5550, 6550
So...
You DVR must be with Manual IP
And then, open the router management page and configure NAT settings, so that when someone in the outside network "calls" you ip+port, the router knows to which machine the "call" is...
Also... use some kind of dynamic dns service like DynDns or NO-IP so that people use an regular URL and not a IP address.
Posted on Sep 15, 2009
SOURCE: how do i install ip cameras so that i can see them
Can I use a share IP address from my ISP to connect and view IP camera on the internet.
Posted on Sep 25, 2009
  • 9 Answers
SOURCE: After install, can't get pictures to show up on
transfer image than use photo shop or other image software
Posted on Dec 01, 2009
Can I Add Audio o My DVR? And How Do I poperly Connect Wires From DVR to TV?
If you have audio capable cameras then you can run a new wire up to the camera(22awg shielded) back to the DVR. If you do not have a camera that can handle then you will have to buy a separate audio device out where you want it and still. wire it back to the DVR.
Feb 05, 2016 | Televison & Video
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
Jun 28, 2015 | OUTDOOR Home Security
Camera reads only static
try to configure it alone separated from the holl system
Mar 26, 2014 | SWANN Home Security
No sound floureon dvr
have floureon 8 channel dvr but cannot get the sound to work or the motion detection buzzer to work. it is not my wiring or cameras or microphone as all worked with the previous dvr correctly. have bought another microphone, camera and dvr compatable and linked it straight to monitor and it works. plug into floureon dvr/no sound. my previous cameras and dvr gave motion detection buzzer no probs, but no buzzer from floureon box/help
Jan 30, 2014 | TOA Electronics TOA NX100S Network Audio...
How to hook up audio
Connect a microphone and enable the audio. It should all be in the settings. Check each camera to make sure audio is enabled. Usually it is off by default.
Jun 24, 2013 | Zmodo dvr-dk41103-1tb cctv 4 ch home...
My dvr watch,cannot display video nor audio after recording.it shows server execution failed
Hi. Sorry for my english. install on your PC the VLC media player (free download) and then try to play the videos with this.
Good Look
Feb 09, 2011 | Water Proof Watch Dvr Spy Cam Audio Video...
Samsung shr-1041k CCTV system with 4 cameras.
on most dvr 's the port is 80 for the web cam. you also need to set up the network settings and know the ip you are trying to hit and is it static or dynamic if dynamic it will change periodicly. for example if you set the network settings on the dvr to the rang of your local network it would be something like 192.168.1.10 so under your router you would open port 80 to ip 192.168.1.10. make sence. first thing i would do is make sure the network settings in the dvr are set to work within your network. unless you have an extra static ip you can put it right into the dvr. fi you need further help just ask.
Nov 03, 2009 | Samsung 4 Channel Dvr
Security First SDVS-1904 Setup (Not D-Link) Needing help with this. We installed the 4 cameras and the DVR. They're working fine. Now I'm trying to get it to come up on the computer so we can see the...
I'm not sure if you are still looking for the answer, but I think the problem may be that you need to enter the PUBLIC IP address of the modem at the remote end instead of the PRIVATE (ie. 192.168.1.x) IP that was actually assigned to the DVR. It works best if you assign a static IP to the DVR on the remote end and enter that IP into the router's DMZ. You might also want to get a free account at dyndns.net and setup a FQDN for your business router/modem. That way you can connect to it using something like "mybusiness.homeip.net" instead of an IP address, and if the IP changes it will still find it. You will also have to configure your modem at the business to automatically update the dyndns server when the IP changes.
Mar 04, 2009 | D-Link Securicam Network DCS-950G Wireless...
I nd to configure dynamic host for my dvr camera through router
You need to assign static IP on your dvr camera, then open the port(port forwarding) for your camera using the router's setup page.
Jan 18, 2009 | Linksys Wireless-G WRT54G Router
Home Security Logo
Top The Home Security Experts
vince
 MikeWang
MikeWang
Level 1 Expert
Are you a The Home Security Expert? Answer questions, earn points and help others
