Question about GPS
I have a golf buddy dsc-gb700. The chrage cable connector seemsto be lose and won't charge with out pushing the cable to one side.
Our Golf Buddy watches no longer charge and last for 18 holes
Hello -
Have you considered replacing the rechargeable batteries in the watches?
Rechargeable batteries do not last forever, eventually losing their ability to hold a charge.
Make sure you obtain the right rechargeable batteries for the watches and dispose of the old batteries properly at a location which accepts such batteries for recycling.
Best wishes.
Jan 30, 2018 | Buddy GPS
Battery replacement for golf buddy range finder
Ask on Internet , All cell types available , even advises you on different make & types, See if you can get old Battery out of Buddy Range Finder,
Mar 14, 2015 | GolfBuddy Golf Buddy - dsc-gb200 - Golf...
My lithium battery has died out. can I use conventional batteries, chargeable or non- chargeable ?????
Lithium batteries are the best for products that use a high amount of electricity. Examples are flash cameras and high intensity lights. They are also good for cold weather applications because they remain chemically active at low temps.
I have a golf buddy that lose it charge after about 11 holes can I replace the batteries?
I also had the same problem of the battery not lasting a whole round. I found out that if the unit was left for any length of time after it had been fully charged, it would start to discharge even though it was turned off. I now make sure that if I'm playing golf the next day I will put it back on charge overnight.
this has worked successfully for the last 5 months approx
i also looked to find a replacement battery but without success
hope this helps
Feb 22, 2015 | GolfBuddy Golf Buddy VOICE GPS
I plug in to AC charge for the whole day and try to turnon, with switch on the right hand side, nothing happened
On the occasion it won't chrage the PSP. You should double check that it is charging it. Also, try to see if it'll turn on while plugged in. If it turns on, let it charge, if it doesn't either the battery is shot or the plug-in spot is broken or not responsive.
Sep 12, 2011 | Sony PSP (Piano Black)
In my dell lattitude600 the battery status is idle thats why its not chraging.then what can i do to cherge battery again
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 20, 2011 | Dell Latitude D600 Notebook
Hello i put my boster cables on back words haha and it wouldnt run after so I changed my battery and altonighter and now my battery won't keep a charge it's getting charged at 11volts and now my...
It sounds like what you fried is the diodes on the alternator. You are probably due for a new alternator. On the bright side, it's much cheaper than the computer.
Jun 24, 2011 | 1998 Ford Explorer
I dont know how to chrage a eclipse media player
I had the same problem too, First off it is the dark color that is highlighted not the light color. i think i was getting that confused at first and then also you have to push the m pretty fast. You may also have to name it first cause i did figure out how to do that first and then it charged. To name it have windows media player plugged in and turn it on. When it is charging it says charging now if it doesn't you did something wrong.
Dec 25, 2009 | Eclipse TCH828 Digital Media Player
GPS Logo
46 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
