Question about Tools & Hardware - Others
Where can I purchase a drive belt for a gmf k1440 wood lathe
The wood lathe is a 1988 mod.no.k0-1440. ser no. 003097
al_kupchella
  • 843 Answers
SOURCE: how can one use a
You need a phase converter. The link below is a a selection from Grizzly. You can also find them on e-bay. There are two types - static (no moving parts) and rotary (much more expensive). The rotary type give you full performance delivering true 3-phase power to your machine. But for a minor loss in power (maybe 20%) the static type does the job quite well - assuming you don't need all of the power that your 3-phase motor can deliver. Here's the link: http://www.grizzly.com/products/category.aspx?key=275030
good luck. Vote if you found this helpful. Al K
Posted on Sep 09, 2010
HansPP
  • 2510 Answers
SOURCE: I have aClarke CWL6 500mm/20inch
Belts are measured on their outside (wide) circumference. Place the belt adjustment in the middle of its travel and measure the length around the outsides of the two pulleys with a tape measure. This will give you a good idea of the length, accept a belt a little shorter if need be. You also need the width of the belt, this is the width across the pulley groove. Take a piece of the old belt with you to the belt dealer for him to match the belt cross section. (An automotive belt will probably be the wrong section).
Posted on Feb 02, 2011
heatman101
  • 43501 Answers
SOURCE: toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
Posted on Feb 26, 2011
jyackle5
  • 8197 Answers
SOURCE: Where ca I get parts
Sorry mastercraft tools are made by Canadian Tire. You can not get parts for the item They will not sell parts or supply them. We get a lot of requests for parts and have called Canadian Tire and they will not tell us where to get parts. You can try to call them at (1-866-746-7287) or here is the mastercraft tool direct line. 314-429-3333
Posted on Mar 30, 2011
SOURCE: I need a manual for
I have the lathe and got a manual emailed to me from the jet people since it doesn't show on their web page. I just called them off the contact us link.
Posted on Sep 17, 2011
Looking for a live centre and drive end spur for a Mastercraft 554508-0 cast iron wood lathe
Such accessories tend to be universal rather than dedicated to any particular make or model of lathe.
Such accessories are available from many outlets and catalogues containing items for the wood-turning enthusiast.
The tailstock of most lathes would be produced with a Morse taper numbers 1, 2 or 3 and with a variety of adaptors a number of live or dead centres, drill chucks or morse taper drill bits can be used.
Similarly the headshock spindle should be found to have a standard thread capable of accepting a number of chucks, faceplates, drive spurs and so forth.
The headstock spindle thread and the tailstock taper should be listed in the machine specifications and then armed with that information you can shop around a multitude of suppliers to find the best deal.
Apr 19, 2016 | Tools & Hardware - Others
Where are the gears ?
I see no gears in the manual You can move the belt over to get a different speed if that is what you are asking.
http://content.wmhtoolgroup.com/assets/manuals/1352001_man_EN.pdf
Nov 28, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Motor stopped while turning. It does have power but will not run.
Motor should have red push botton on back or bottom of motor. This is reset over load breaker . Should be out, just push in until it clicks.
Feb 15, 2013 | Powermatic 1352001 3520B 20x35" Wood...
My wood lathe is making noise
Thats a good thing, means you making chips. lol. What kind of noise exactly?
Oct 09, 2012 | Powermatic 1352001 3520B 20x35" Wood...
Fox mini lathe not running right
Could you be a bit more specific? This is a very simple machine...it either works or it doesn't. Have you checked the belt? Is it binding, or cross-threaded on the drive spindles?
Jun 16, 2012 | Shop Fox W1752 Mini Wood Lathe
Toro powerlite 98 cc 16" Mod no 38182 ser
heatman101
Feb 26, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
I have aClarke CWL6 500mm/20inch motorised wood turning lathe.I am trying to find a driving belt for this model. The original belt has disintigrated and I don't know the size I need or where I can purchase...
Feb 02, 2011 | Garden
Noisy headstock on 15 inch variable speed lathe
Usually not. Is lathe leveled, and base secured, check for soft feet. This can set up vibration and load bearings.If motor is belt drive check belt condition, pulley alignment, belt tension.
Jul 29, 2009 | Tools & Hardware - Others
Looking for info/ manual for a wool lathe
look under cwl12d clarke wood lathe manual. this has all the instructions that are almost the same as the nwl37-2 i have a nwl37-2 and this manual shows what should be there.
Jan 22, 2009 | Powermatic 1352001 3520B 20x35" Wood...
Tools & Hardware - Others Logo
47 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
