Question about Asrock 845GV (P4I45GV) Motherboard
  • Anonymous Aug 07, 2008
    xp install error
  • 4 Answers
What's the error?
Posted on Nov 20, 2007
Comp will not boot after installing a SATA DVD-RW
Perhaps your bios is set to boot from the 1st device it 'sees'.
When you add the dvd drive, maybe the device order gets shuffled up, making the dvd drive 1st. So, you need to check this by looking at the boot settings on the bios screen and change the boot order if necessary.
Sep 24, 2012 | MSI Ms-7529 V1.6 Motherboard Intel Lga775
Can't find updated ACPI Bios for toshiba satellite m45 s331I am Getting blue screen Bios in this system not fully ACPI compliant.
Upgrading the bios it will not fix the issue ..cause the blue-screen is either a unsupported setting is a operation system issue ..So ..if you get the blue-screen when you boot up ..and does not let you to get into bios..It may be the ACHI (not acpi ..cause the acpi is the power management ) being enabled and not having the driver installed..and in this mode will not be able to boot and will give you that blue screen ..
To fox it ..just go to bios ..and look for the hard disk ..and in teh same category you will see the achi function ..and just disable the mode..and let it run as IDE..This way it will boot fine ..
Indeed the achi mode for a hard disk faster and if you do want to use it ..try to boot without the achi enabled..and install the achi driver in the system ..and after that enable it again and see if it works..
If it still does monkey business than it will have to be reinstalled ..and if you still want achi for hdd have to install the driver during the installation a 3rd party driver ..
In short ..try to make it run ..and do not mess with the BIOS ..cause you may end up with a broken laptop ..
Feb 17, 2011 | Toshiba Satellite M45-S331 Notebook
Can't install xp in compaq laptop
you mean you need to downgrade your computer from Windows Vista to XP?
if so is the case, you need to go to the BIOS in the Boot menu, select IDE from ACPI.
put the boot option to boot from CD first or disable Boot from hard disk.
then you will be able to downgrade your computer from Vista to XP.
Jun 07, 2010 | Compaq Computers & Internet
Blue screen ACPI.sys on install (brand new system, first install)
my client office one system working windows , when booting time displaying blue screen error" acpi.sys " . and then continusly system restart., but, i was maked the first and second repair, still now i didn't got solution for this problem. please help me. and also i want need ur help for blue screeen error.
May 15, 2009 | ASUS Computers & Internet
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Wont boot into safe mode, hold up at loading driver acpi multiprocessor PC
do you have XP bootable CD? If yes goto BIOS settings and select primary booting device CD Drive and save settings and exit. After restarting your system You will be asked to press any key for installing the OS.
Oct 29, 2008 | Microsoft Windows XP Home Edition
Windows XP Problem
if you got the OS cd, insert and boot from cd and try a repair.
or check for solutions in the solution range i used to fix similar problem from
solution dictionary for fixing all pc problems on htpp://
Oct 29, 2008 | Microsoft Windows XP Professional for PC
Overclocking past 2.7GHz with Q6600 GO step
Please check BIOS update from mainboard manufacturer website it there has a solution for overclocking and others. Else don't push your motherboard so hard, you might get extraneous problem.
May 28, 2008 | Foxconn N68S7AA-8EKRS2H nForce 680i SLI...
Problem on o/s installation
Look in your bios & see if you can disable the ACPI, (which you should be able too do. Finish installing your OS. Than update the OS. After completing all updates re-enter your bios & enable the ACPI. You should not get that error message after re-start.
Boards that support ACPI will get this error during a fresh install untill they get windows updated. All OS's
Post back if this did not help! It worked for me.
Please vote..
Jan 28, 2008 | Intel D945GNT Motherboard
Asrock 845GV (P4I45GV) Motherboard Logo
124 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
