Question about Friedrich QuietMaster SL28L30 Air Conditioner
I don't think the thermastat is working. It will not come on as often as it should. It is cooler outside than in. Can it be fixed and how?
    President:
  • 1,922 Answers
Is the thermostat out of a cool draft of the unit???if not A/C is cooling thermostat and defeating the purpose,change thermo location and retry
Posted on Jul 30, 2009
Will a auto transmission cooler from a ED falcon fit an EF falcon
If it is in the radiator it should as the fittings are the only problem you are likely to encounter. If you are wondering if the cooling capability is affected consider this . Hot tranny oil has to be cooled in the radiator water and this heat makes the radiaror work hard.Why don"t you consider a external cooler. They keep the oil cooler as they are are running in the outside air. Ie air temp 30 deg C oil temp 150c+ water temp 85degC oil temp 150c. You can see that the tranny oil looses more heat and it will not overload the radiator capability
Jan 26, 2013 | Ford Cars & Trucks
Proview 3200 wont work w/ outside antenna
I don't think it has ATSC tuner at all. In other words I don;t think it will work with an inside antenna either.
or if it does...just use the inside one :-)
Oct 01, 2012 | Proview Televison & Video
I seen to have a pink fluid in my radiator I think its trany fluild how the hell did it get there??
look at the bottom or sides of the radiator. if there are lines running into the tank other than the radiator hoses the transmission cooler is part of the radiator and most likely began leaking into radiator only fix is to replace it
Aug 18, 2012 | 1996 Mercury Mystique
My 2002 Toyota Celica fogs up and collects moisture on the windshield during or after a rain. Visibility is a major problem. Need help, this is truly unsafe.
Can be that your heater core or hose inside car is sometimes releasing alittle heat at the clamps. So long the inside of the floor is not wet or damp or car is not over heating. I would not worry about the heater to much inside unless this does not work...
Change the automatic climate control up or down to cooler or warmer i usually run it at least upto 10 or 20 degrees different than the outside anytime i drive mainly during rain or snow.. So if outside it is warmer means you need to be cooler and cooler means get warmer. Also If you don"t run that on a regular basis a quick Ac on and defroster front and back works well and generally fast.I really think that is all of your problem just get comfortable with your automatic climate setting. once in a while it may happen again only because of rapid temp. changing from outside air to inside air in your car..Rain X works really well for a couple weeks between apps.and saves wiperblades during raining times. Always drive safely and good luck 11_21_2011_5_34_27_pm.jpg
Aug 16, 2011 | 2002 Toyota Celica
Oil in the engine coolant. no oil in water. I don;t think it is trans. fluid from cooler in radiator.
The seals on you oil cooler are gone. The oil cooler is located under the intake manifold. Hopefully you haven't driven the vehicle far because the grey mud created by the mixture with bake onto your engine walls sealing up the ports. It's best to have Ford (or a damn good mechanic) do the job as the whole top of the engine basically has to come apart. Roughly $3000 to fix providing you haven't damaged anything else. After the seals/oil cooler is replaced, you should flush your coolant at least 3 times. Good luck!
Mar 11, 2010 | 2006 Ford F-250 Super Duty
The outside ridge between the freezer and cooler
I would guess that the condenser fan isn't running. It's underneath the fridge behind the cardboard cover on the back. It should be running when the compressor runs. You can place your own fan on the floor blowing under the fridge till you get it fixed.
Jan 17, 2010 | KitchenAid (KSRD22FKST) Side by Side...
My coolant light came on about a week ago. I am busy and trying to get in some where. Today it reached freezing temp outside. And about 3 days ago my blower stopped working. I am now unable to defrost the...
If it isn't over heating, then the coolant light means it's low on coolant, just add some to it, but don't fill it to the top.
As far as the blower, if the fuse is good , have the relay switch checked, or the blower motor it's self might be no good.
Sep 30, 2009 | 1993 Volvo 850
How to clean/repair water cooler
I have a hamilton beach water cooler with storage cabinet # 87330. The cold water is not cold and the cooling light stays on. What is the problem and how can I fix it? Thanks!
Jan 07, 2009 | Hamilton Beach Water Cooler with Storage...
Magic chef wine cooler
That means couple of things. The cooler's glass door is poorly insulated, and the cooler is placed in a humid environment. To eliminate the sweating you can run a dehumidifier close to the cooler, or you can insulate the inside of the door with styrofoam but that's going to spoil the look of the cooler.
Aug 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Refrigerator blowing warm air.
check the thermastat with power off remove one wire on the thermastat and read across the two terminals of the thermastat with an ohm or resistance meter if set to highest setting on the thermastat you should get a resistance reading if you don not the thermastat is vad
May 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Friedrich QuietMaster SL28L30 Air Conditioner Logo
85 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
