How do you clean the eyes? - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 8,204 Answers
What do you meen by the eyes? or are you on about the laser that reads the discs ?
Posted on Dec 24, 2016
"no disk" message, intermittently plays disks.
sounds like the eye is dirty use a little rubbbing alcohol and a soft lint free cloth (like you use for cleaning glasses and wipe the eye area clean DO NOT USE WATER TO CLEAN THE EYE ) rubbing alcohol evapourates quickly water doesn't
Sep 21, 2013 | Audio Players & Recorders
How to clean eye of dvd player?
You can buy discs that are made for cleaning the laser on a CD player. They look like regular CD's, except they have little bunches of really fine hairs on them. If you just want a do it yourself way, I would use a q-tip and some 99% Iso (rubbing alcohol). The iso will evaporate so you don't need to worry about any moisture left behind.
Sep 25, 2012 | Panasonic DVD Players DVD-LS92 DVD LS92 -...
My fellows PS-65S electric eye has been cleaned and still won't take paper to shred
I have had the electric eye come out. they kind of lock in there. I have had a couple push back. I had to take glue the electric eyes into the slot. like I said I have had this happen on two fellows shredders.
good luck
Jul 18, 2012 | Office Equipment & Supplies
The shredder doesn't turn off
Try cleaning the eyes in the middle where you insert the paper they may be dirty. If cleaning dosnt help then the eyes or pcb inside could be defective.
Feb 06, 2011 | Aurora Global AS702MX Shredder
Hi my sony dvp-fx820 keep giving me "Can Not Play the disc"???I Message.I have other dvd player it also giving me same Message I Accidently Pushed the progressive button. I'v fixed the problem by...
Laser probably needs to be cleaned. If you can get to the laser eye, check for scratches. With a foam cue tip or lint free cloth, not a cotton swab, with very very light denatured alcohol wipe the eye clean of debris. Clean eye once again with a dry lint free cloth. Check again for scratches, if no scratches the eye should be clean. If this doesn't work, try flipping the player upside down and secure where player is steady. Push the play button and see if it will play. If the player works in this position, that means the mechanics that move the eye up and down are weak. The entire eye assembly needs replacing.
Nov 02, 2010 | Sony DVP-FX820 DVD Player
My xbox360 won't read disc, spins for awhile and
The best bet is to try and clean the laser, if the unit is under warranty, contact microsoft and send it back, if not, dont use a laser cleaning kit, they are useless at cleaning and excellent at spreading the grime over the eye. Open the case, an online guide will help you learn the art of pulling apart the xbox, dis-assemble the dvd drive assembly and clean the laser using a cue tip or cotton bud. Good Luck.
Nov 23, 2009 | Microsoft Xbox 360 Console
Phase linear uv8 DOSE NOT PLAY DVDS
Remove cover of player, you will see glass eye which is laser eye. Take rubbing alcohol and cotton swab and clean the eye with the alcohol soaked cotton swab. If this player is self- fixable, than this will do the trick. If cleaning the laser eye didn't help, than they player will have to be repaired or replaced.
May 04, 2009 | Televison & Video
JVC tha75 r where is laser eye bit so i can clean it?
When you say laser eye, are you referring to the laser used to read your cd's & dvd's? if so, you can find dvd cleaners at most retail stores. the kit will contain a disc that looks like a dvd with built-in brush & cleaning solution. follow the instructions on the cleaning kit & you should be OK. reply if you need additional assistance.
Feb 05, 2009 | JVC TH-A75R System
CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Oct 05, 2008 | Teac DC-D2831 CD Shelf System
Cd player not working
  1. its eye unit may in trouble, clean eye by using a eye cleaning cd
  2. eye alignment is failed, adjust the eye by adjust the screw on the eye
  3. cable may loose contact, re fix cable, check cable replace cable if necessary
  4. low power supply problem, check supply voltage, if it low simply add a filter capacitor of 4700uF/40V accross it.
  5. some time its main board may problem, check and replace it
Jan 16, 2008 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
