Question about Fitbit Inc Fitbit Force
I have had my fit bit for about 6 months. Last night the battery drained. I charged it over night and now the clock is off by an hour and a half
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
    Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
    May 08, 2015 | Watches
    It's a 3 key chime and strike clock that chimes every 15 min and strikes hours. for last one month it doesn't chime at 12, 3, 6, and 9 position and the hour strike is not synchronous with min hand
    More than likely, there are springs that activate the levers for it to chime, or bong, they may have got jammed up, you can open it up, and see if you see anything like that, if not, you will have to take it to your local jewelry store, or watch/clock makers to have them take a look. You never indicated what type of clock (make or model) so I can\'t be certain. Maybe a ships clock? They may want to charge you for a overhaul of the movement, but you can tell them to just "make it work" if it was running fine before (keeping time well) then an overhaul probably isn\'t necessary. It sounds like something may have got jammed.
    I hope this helps !
    Nov 16, 2013 | Watches
    I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
    With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
    Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
    Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
    Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
    Hope this tip guides you to a solution for your clock.
    r/ David
    http://antiqueclock.clockstop.com/
    Apr 06, 2010 | Watches
    E010 S95986 HSB power cell does not hold charge
    Change the capacitor. This is the thing accumulating the energy. As the ordinary batteries, it may go bust, so, all you have to do is to replace it. There is no such a name as power cell in Citizen EcoDrive watches - there are CAPACITOR. Capacitor absorbs the energy from the light sensitive panel(s) and dispenses it in the ordinary battery manner. Advertisements are saying that you will never have to change the battery - that's right, because there are no batteries at all. Instead of battery there are CAPACITOR, but nobody says it will last forever. Rate me, plz.
    Mar 05, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
    Our swiss railway wall clock runs very slow. changed batteries twice in 2 week period but it loses an hour or more per day. help! a lot of money for a clock that only worked a couple of months.
    If it is within the warranty period (usually a year), then you should return it to your supplier, with an explanation of the problem.
    They should replace it free of charge.
    Jan 25, 2010 | Oregon Scientific Watches
    Casio Pathfinder PAG-50 battery replacement
    ensure all three of the springs are present
    the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
    ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
    Mar 28, 2009 | Casio Watches
    Setting instruction for Accurist world time wrist watch
    Same just happened to me, performthe following:
    The analogue hands are not precisely synchronised with
    the digital time?
    1. Press the lower right button to move the mode indicator
    hand to CHR.
    2. Pull the lower right button out one click. The hour, minute
    and UTC hands will retract towards the straight up 12 O’clock
    position. You will see UTC on the top half of the digital display.
    3. Press the upper right button to advance the hands to the
    straight up 24-hour position. Use the lower left button to go in
    reverse.
    4. Press the upper left button. You will see HR on the top half
    of the digital display. Press the upper right button to advance
    the hour and 24-hour hand clockwise until they both point
    straight up at the 24-hour position. Use the lower left button to
    move the hand anti-clockwise.
    5. Press the upper left button. You will see MIN on the top half
    the minute hand clockwise or the lower left button to move
    anti-clockwise until it is pointing straight up at the 12 O’clock
    position.
    6. Push the lower right button back in one click.
    The watch malfunctions in some way and the above
    procedures do not work.
    1. Press the lower right button until the mode indicator hand
    points to TME.
    2. Pull the lower right button out one click. Press the other
    three buttons down simultaneously for three seconds and
    release. You will see 8’s on the digital display.
    3. Press the upper left button. You will see UTC on the top half
    the hands of the top dial to the straight up 24-hour position.
    Use the lower left button to go in reverse.
    position.
    Jul 06, 2008 | Watches
    Fitbit Inc Fitbit Force Logo
    14 people viewed this question
    Top Fitbit Inc Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Fitbit Inc Watch Expert? Answer questions, earn points and help others
